indigo is far far the clearest of all!
Indigo 0.9.6 Vs FryRender 1.8 demo(up-date)
- Kosmokrator
unfortunaly...as i can see the fry render image exept the contrast (i like it)...i think it have more correct shadows in the room....i dont know how much the same is the scenes between renderers.....may be i try and one test my self soon with thees 3 progs!
the last image to compare Indigo 0.9.6 Vs maxwell render 1.5 Vs fryrender 1.8......all the image they have been realized whit the same workstation in 32 minutes......whit connection to 3d studio max 9
I leave you the appraisals
filippo
sorry for my poor language
filippo
- fryrender(exit portal on)
- fryrender exit portal on.jpg (474.67 KiB) Viewed 9917 times
the comparison......indigo 0.9.6(exit portal on) Vs Maxwell render 1.5 Vs fryrender 1.8(exit portal on) 32 minutes of render
- ALL IMAGE
- TOTALE.jpg (265.14 KiB) Viewed 9914 times
My speed tests, for picture quality comparison.
- fryrender image, 50 mins.
Supersampling ON. - output_002.jpg (64.61 KiB) Viewed 9842 times
- fryrender image, 10 mins.
Supersampling ON. - output_001_.jpg (78.74 KiB) Viewed 9882 times
Supersampling OFF. - output_001.jpg (65.15 KiB) Viewed 9867 times
- This is Indigo PT+BiDir, 50 min. render, crisp and nearly clean! I really like the AA, very detailed render quality!
- winner!_mayak_050_vray50night_indigo.max-50min.jpg (85.22 KiB) Viewed 9875 times
- This is Indigo PT+BiDir render, 10 mins.
- w_mayak_050_vray50night_indigo.max-10mins.jpg (132.07 KiB) Viewed 9893 times
bluriness has nothing to do with noise cleaning but with AA filtering. Real cameras are a little blurry too, that's why your 8Mpixels photos looks better downsized.vansan wrote:Maxwell 1.5 and Fry beta1.8 sacrificed the sharpness of the render to speed up noise clearing.
Indigo is the best!
there is a little checkboxe called "S" near the output size. if checked, it enable supersampling. in most cases it's useless and memory hungry so it's off by default. that's all.
sharpness/blurrines is really just a matter of AA filtering.
fry used to have a whole set of AA filters, including box filtering (very sharp and basic), but we decided that fry should include the fewest settings possible on the rendering process, so that you tweaks settings only if you need them.
BTW, are you sure your camera focus point is OK ? just wondering because the blur here is a little bit stronger than usual.
I prefer indigo than fryrender. I like the indigo result. But fryrender it's more complete, has a great menu with a lot of options, you can config in the menu the lights, cameras, surfaces, etc.. indigo only has a menu in the exporters. If indigo one day would have a menu such as fryrender indigo would be one of the most renders engine.
Sorry for my poor english.
