Indigo 0.9 test 5 (x86 and x64 builds)
Kosmokrator
Post by Kosmokrator » Sat Aug 11, 2007 8:05 am
generally microsoft kram1032...our systems based on ms software...and indigo lids and bin code too.....so...its some MS mess with dlls and libs....
Ono...i think its easy to find a virgin XP system....Make a partition in your disk and instal a fresh copy of xp to test what happents here...
mrCarnivore
Post by mrCarnivore » Sat Aug 11, 2007 8:12 am
The sss bug is still there!
Camox
Post by Camox » Sat Aug 11, 2007 8:17 am
ZomB wrote:Maybe Microsoft Visual C++ 2005 Redistributable Package (x86) is needed... give it a try Camox.
I have it new installed and the same error :cry:
Post by Kram1032 » Sat Aug 11, 2007 8:38 am
*translating*
This application couldn't have been started, 'cause it's configuration isn't correct. To fix the problem, you should reinstall the application.
Indeed not very helpful....
Camox
Post by Camox » Sat Aug 11, 2007 8:52 am
thx kram, my personal translator ! :D
greetz
zsouthboy
Post by zsouthboy » Sat Aug 11, 2007 9:04 am
Ono, install VMware Server or Virtual PC (they're both free) - and create a "virgin" XP install in there, for testing of things.
You can set it up so that ANY changes made are not saved to disk - e.g. you start a fresh install, every single time you boot the virtual pc.
EDIT:
While I'm talking about it anyway, lemme chime in with this:
All my dev tools and such are installed in a VPC image - so all my coding is done in a virtual pc.
That way I can bring the exact environment to anywhere, and get stuff done.
It is indeed slower than native, but I spend the majority of my time typing in an IDE, so it doesn't slow me down ;) The benefits outweigh the slowness.
Every once in a while, I simply copy the VPC image to a backup place of some sort, and then I have backups of everything and anything I did, without having to deal with versions and other bullshit.
It really is quite great :) I highly recommend it.
deltaepsylon
Post by deltaepsylon » Sat Aug 11, 2007 9:08 am
gah... right when i get my computer taken away, ono decides to release t5 ... :(
richie
Post by richie » Sat Aug 11, 2007 10:31 am
same error here (in french) on winXp, 32 bit (x86) distribution
Post by Zom-B » Sat Aug 11, 2007 12:32 pm
Ok, now I can confirm this error too, tested on my girlfriends Laptop WinXP home SP2 32bit... :(
The Laptop + System is about 1/2 year old, and only used for Internet, music, picture viewing and Office related stuff.
BTW: I discovered, that Network rendering is possible between diferent Indigo versions.
Perhaps something that should be prevented...
Wedge
Post by Wedge » Sat Aug 11, 2007 1:01 pm
Hello,
Just opened the 32 bit version ok here on my old pc running WinXP. Not anything special about my pc, I keep it updated if that helps. Thanks for this release, it is about time I render a nice scene soon. :)
CoolColJ
Post by CoolColJ » Sat Aug 11, 2007 1:15 pm
32 bit version working fine here, resuming a render right now :)
Xman
Post by Xman » Sat Aug 11, 2007 11:05 pm
Similar Vulture,have a similar problem. :(
Win XP 32 bit ,AMD X2 3800 dual core CPU and 1Gb memory.
Post by suvakas » Sat Aug 11, 2007 11:11 pm
Tested on another Xp 32bit with SP2 - works fine. Very strange that it doesn't for some.
Anyway. It really is faster even with simple scenes.
I did a 2 min test with cornell box.
test4: 11.62500 samples per pixel
test5: 12.43750 samples per pixel
Good work Ono! Indigo is geting better and better.
ribo
Post by ribo » Sun Aug 12, 2007 12:18 am
32 bit distribution working fine, but I get the above mentioned error message for 64 bit.
I am in Win XP 64-bit with SP2.
Thanks Ono for your great work.
Post by OnoSendai » Sun Aug 12, 2007 12:23 am
Hi.
If the normal 32 bit build is not working, try downloading this:
http://www.microsoft.com/downloads/deta ... laylang=en
For the 64 bit builds, try downloading this:
Please let me know if that works.[/url]
