Indigo 0.9 test 4 experimental 64-bit build
filippo
Post by filippo » Wed Aug 08, 2007 10:53 am
wonderfull work!!
filippo
filippo
Post by filippo » Wed Aug 08, 2007 10:59 am
as I can understand the speed of the pc?
what I must look?
thaks
filippo
thaks to image to CARONTE
image from CARONTE (indigo user)
Post by Kram1032 » Wed Aug 08, 2007 11:19 am
it's the same, but reversed. you can look at both.
it's like
x
and
1/x
nothing else.
matt
Post by matt » Wed Aug 08, 2007 1:39 pm
You want to look at the second line. The samples / second (or its inverse seconds /sample) let you know about the speed of the computer.
The second line just tells you how many samples have been rendered per pixel. It tells you more about the quality of the image than the speed of the computer.
ianammo
Post by ianammo » Wed Aug 08, 2007 7:06 pm
Argh! - I got all excited but it doesn't want to run for me - are there some new dependencies that I mightn't have installed?
I'm running Windows XP Professional x64 edition with SP2. No problems with the 32 bit builds, but when I start this build I get:
"The System cannot execute the specified program."
In the System event log I get the following:
SideBySide: Component identity found in manifest does not match the identity of the component reqested
SideBySide: Synax error in manifest or policy file "C:\indigo_09_test4.5_x64\Microsoft.VC80.CRT.MANIFEST" on line 4.
SideBySide: Generate Activation Context failed for c:\indigo_09_test4.5_x64\indigo_console.exe. Reference error message:The manifest file contains one or more syntax errors.
I also tried on a one of the XP x64 work machines, and got the same response.
deltaepsylon
Post by deltaepsylon » Thu Aug 09, 2007 2:17 am
BUG TIME!!!! INSECT REPELTENT!!1 *Spray around the forums* all works now :lol:
psor
Post by psor » Thu Aug 09, 2007 4:17 am
ianammo wrote:Argh! - I got all excited but it doesn't want to run for me - are there some new dependencies that I mightn't have installed?
I've tested the build on my x64 workstation (WinXPx64SP2) and ran into
the same problems ... :/
take care
psor
"The sleeper must awaken"
dougal2
Post by dougal2 » Thu Aug 09, 2007 10:52 am
i can confirm it's working fine here on vista ultimate 64bit, with the latest blendigo exporter.
(I copied the indigo_console.exe to indigo.exe so that the export would find it; it works :) )
Post by OnoSendai » Thu Aug 09, 2007 10:55 am
So it seems there is some kind of manifest problem on XP 64 bit... ok.
filippo
Post by filippo » Fri Aug 10, 2007 1:12 am
I USED INDIGO 0.9 IN VISTA 64 AND IT'S WORK!!
what is the differet among indigo 32 and 64 bit ?
I used indigo 0.9 on vista 64 whit 3d Studio max 9 64 Bit
filippo
Post by Kram1032 » Fri Aug 10, 2007 1:26 am
64 bits is compiled for 64 bit -> faster.
even before compiling for 64 bits, there where other speedup thingys, post relsase, so -> even faster.
deltaepsylon
Post by deltaepsylon » Fri Aug 10, 2007 4:22 am
edit: link and text removed cuz zsouthboy thinks it might insult ono :?
zsouthboy
Post by zsouthboy » Fri Aug 10, 2007 5:14 am
deltaepsylon wrote:ono should start looking even more into optimization. i was surfin the net ysterday and found this, might be of interest: http://www-d0.fnal.gov/KAI/doc/UserGuide/chapter_3.html
I don't know how to phrase this:
1) Premature optimization is the root of all evil. Period.
2) The link you posted, and the way that you posted it, implies to me that you are not a programmer, or have not been one for long.
Ono is hardly new to C++ - it's almost insulting to post that link. He knows what he's doing in regards to (incredibly simple programming concepts) that. Take a look at the code that he has released for other projects for proof.
deltaepsylon
Post by deltaepsylon » Fri Aug 10, 2007 6:30 am
ok ok sorry :?
you are right, i havent been a coder for a long time, and i code mostly in MATLAB for math stuff that pple hire me 2 do.
besides, me only 14
manitwo
Post by manitwo » Fri Aug 10, 2007 6:37 am
therefore stop using the term "ono should ..." :roll: (thats not the first time)
