greek
(o exporter analamvani na trexi to indigo den xriazete na to trexis esi...apos patas to render ston exporter.....prota omos prepi na setaris thn skinh su me ta indigo materials ktl...ti akrivos provlima exis?) :wink:
------File loading settings------
--"scenefilepath" "D:\programming\models\ior.xml"
--"scenefilepath" "D:\programming\models\testscenes\antialias_test.xml"
--"scenefilepath" "D:\programming\models\bandtest_original.xml"
--"scenefilepath" "D:\programming\models\testscenes\cornellbox_jotero.xml"
--"scenefilepath" "D:\programming\models\glass_stack.xml"
--"scenefilepath" "\\lust\models\testscenes\dof_test.xml"
--"scenefilepath" "hoela.xml"
--"scenefilepath" "cornellbox.xml"
--"scenefilepath" "\\lust\models\ajax.xml"
--"scenefilepath" "\\lust\models\blenderwine.xml"
--"scenefilepath" "\\lust\models\matpreview.xml"
--"scenefilepath" "D:\programming\models\testscenes\brewsters_angle_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\extinction_test.xml"
--"scenefilepath" "\\lust\models\rainbow_experiment\rainbow_experiment.xml"
--"scenefilepath" "D:\programming\models\testscenes\precedence_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\sss_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\caustic_participating_media_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\simple_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\glossy_glass_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\instancing_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\colour_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\bumpmap_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\phong_test_2.xml"
--"scenefilepath" "D:\programming\models\water_drop\drop.xml"
--"scenefilepath" "D:\programming\models\matpreview.xml"
--"scenefilepath" "D:\programming\models\testscenes\specular_sunlight_test.xml"
--"scenefilepath" "D:\programming\models\testscenes\blend_material_test.xml"
--"scenefilepath" "D:\programming\models\bump_test\default.xml"
--"scenefilepath" "D:\programming\models\joanroig\joanroig.xml"
--"scenefilepath" "D:\programming\models\dragon1\dragon1.xml"
--"scenefilepath" "D:\programming\models\testscenes\sss_energy_loss_test.xml"
--Scene xml file to load. Relative to working directory (e.g. indigo.exe path)
--Alternatively, this path can be an absolute path, eg c:\indigo_scenes\testscene.xml
------Output image dimensions------
"width" "800" --Note that the ratio of these should match the camera aspect ratio defined
"height" "600" -- in the scene xml file.
------Metropolis light transport settings------
"metropolis" "true" --if true, use MLT, if false, use pathtracer
"large_mutation_prob" "0.4" --Probability of using fresh random numbers.
"max_change" "0.02" --max mutation size, must be in range [min_change, 1)
"max_num_consec_rejections" "10000"
------General tracing parameters------
--"russian_roulette_live_prob" "0.999" --0.7
"max_depth" "100000" --max ray bounce depth.
"bidirectional" "false"
------Path tracer settings------
--"strata_width" "5" --number of samples per pixel = strata_width*strata_width
------Network rendering settings-----
"frame_upload_period" "20.0" --number of seconds between uploads of image to network master
------Miscellaneous settings-----
"halt_time" "-1"
"logging" "true" --write to log.txt?
"display_period" "20.0" --number of seconds between display of the render in preview window.
"image_save_period" "20.0" --number of seconds between saves of the render to PNG and EXR.
"save_tonemapped_exr" "true" --Write .exr tonemapped render as well as normal PNG?
"save_untonemapped_exr" "true" --Write .exr untonemapped render as well as normal PNG?
"save_igi" "true"
"num_threads" "1"
"cache_trees" "true"
"polarisation" "true"
"super_sample_factor" "2" --a higher value takes more RAM but may reduce aliasing.
scenefilepath" "D:\programming\models\testscenes\justsomerandomcrap.xml"
Heya MortalMortal wrote:Hello KosmoKrator!!!
ok now i can understand but In C4D Export-> Doesn't have Indigo.
I placed exporter in C4D plugins and only in plugins there is Indigo.
Is this a problem? I can only export from plugins.
For Indigo Materials I will learn soon!!!
Users browsing this forum: No registered users and 46 guests
