Indigo for Cinema 4D 4.0.43.2
- Originalplan®
Re: Indigo for Cinema 4D 4.0.43.2
Export *.igs is not working from c4d's export panel.
Not sure that is supposed to be there. But since it is, I might as well fix itOriginalplan® wrote:Export *.igs is not working from c4d's export panel.
- Originalplan®
Yep just found it too
Tried it did not work.
btw Mr.fused i sent you a msg about another issue please have a look at it if you find the time to do so in the future.Thank you!
@Mr Fused
It would be possible to implement an "infinite plane"?
This was implemented in very early Indigo v1.x versions, but removed because of some massive issues in BiDir rendering, so I think there will be no comeback :/contegufo wrote:It would be possible to implement an "infinite plane"?
you guys are doing an amazing job
This has evolved to be so fine
one thing tho, could vignette be moved to camera setting instead of render setting & defaulted as unused/not active (makes more sense, since the effect is caused by camera)
thanks and enjoy
Years have passed; the problem is so insurmountable?Zom-B wrote:This was implemented in very early Indigo v1.x versions, but removed because of some massive issues in BiDir rendering, so I think there will be no comeback :/contegufo wrote:It would be possible to implement an "infinite plane"?
- Originalplan®
burnin wrote:![]()
No need just adjust your render settings. ( set vignette to off )burnin wrote: one thing tho, could vignette be moved to camera setting instead of render setting & defaulted as unused/not active (makes more sense, since the effect is caused by camera)
thanks and enjoy
And save this as your render preset inside Cinema.
You can save multiple Indigo presets for prototyping and final rendering GPU or Not...if you can click it you can save it.
Which one would that be? I only saw the one about the icon.Originalplan® wrote:btw Mr.fused i sent you a msg about another issue please have a look at it if you find the time to do so in the future.Thank you!
Zom-B is correct here. Would have to ask nick about it. What do you need it for exactly?Zom-B wrote:This was implemented in very early Indigo v1.x versions, but removed because of some massive issues in BiDir rendering, so I think there will be no comeback :/contegufo wrote:It would be possible to implement an "infinite plane"?
Thanks!burnin wrote:![]()
thanks and enjoy
I recently considered putting it on the camera. It really makes more sense on the camera. There are already plenty of render settings on the camera.
Originalplan® wrote:Yes they do a PRO job! Yep Mr.fused is killing it on c4d code.
Hi Fused
"Zom-B is correct here. Would have to ask nick about it. What do you need it for exactly?"
An infinite plane have many softwares used to manage many situations where it is required a background and a horizon that fades over a very large area.
You 'very useful, you can implement today?
- Originalplan®
Yes that's old and it was here. I have been given one @indigorenderer.com by Ono.fused wrote:Which one would that be? I only saw the one about the icon.
Look for a mail with the title " Cinema 5mins to Infiniti " .
- Originalplan®
contegufo wrote:You 'very useful, you can implement today?
Why not use an Alpha render (with no background) and put something behind the render?? Is that no good?
That's... an intetesting object. Worst case scenario, lol.Originalplan® wrote:Yes that's old and it was here. I have been given one @indigorenderer.com by Ono.
Will have a look when I have some more time.
- Originalplan®
Thank you x 1000! Much Appreciated! Yeah kinda worst case scenariofused wrote:That's... an intetesting object. Worst case scenario, lol.Originalplan® wrote:Yes that's old and it was here. I have been given one @indigorenderer.com by Ono.
- Originalplan®
BUG
Obstacle Map's & Aperture Diffraction.
Camera selected they do not work. Camera deselected they show up in PR view.
Worth a look.
Worth a look.
