Mysterious happenings
Re: Mysterious happenings
Post by Oscar J » Wed Sep 09, 2015 3:53 am
Reinhard kinda ruins the dynamics in your image. Experienced users usually use linear or camera. For example the four afgapan camera films gives you low contrast images that you can export as 16 bit tiffs and edit further in Photoshop.
contegufo
Post by contegufo » Wed Sep 09, 2015 3:57 am
Hi
In the last image (Indigo 3.8.26) after 15 min of rendering artifacts not seen.
contegufo
Post by contegufo » Wed Sep 09, 2015 4:05 am
Oscar J wrote:Reinhard kinda ruins the dynamics in your image. Experienced users usually use linear or camera. For example the four afgapan camera films gives you low contrast images that you can export as 16 bit tiffs and edit further in Photoshop.
Thanks for the advice I will do some tests.
Post by Zom-B » Wed Sep 09, 2015 9:28 pm
contegufo wrote:In the last image (Indigo 3.8.26) after 15 min of rendering artifacts not seen.
Have you read and understood my comment regarding this artifacts??!
http://www.indigorenderer.com/forum/vie ... 19#p132419
FakeShamus
Post by FakeShamus » Thu Sep 10, 2015 3:29 am
I think reinhard gets a bad rap, actually. if you use it right it gives you control over the full tonal range of the render and is especially important for retaining shadow and highlight detail. seeing a "long" tonal range like that throws people off cause it tends to look flat, but starting from there and then controlling the contrast and density in photoshop allows you to retain very smooth transitions between tones, especially for specular highlights and deep shadows. just my off-topic 2 cents...
bubs
Post by bubs » Thu Sep 10, 2015 3:34 am
I'd have to agree, for my ArchViz almost all my renders get colour and tone adjustments in PS after the fact. I have found Reinhard to be a good starting point for this on many occasions.
Post by Oscar J » Thu Sep 10, 2015 3:37 am
I guess I just don't like Indigo doing that stuff for me automatically, I prefer a more photographic, realistic raw output and then I'll recover stuff in PS.
But very good points, Fakeshamus.
contegufo
Post by contegufo » Thu Sep 10, 2015 5:14 am
Unfortunately it's artifact random and happens with the version of Indigo 3.8.26.
I adjusted parameters phong IOR = 1 Exponent = 0 but has changed little.
The immgine below are outputs with tone mapping Agfapan-apx-400cd (iso = 200), later in Photoshop adjusted levels and unsharp mask = 30 preserving the lights.
Post by Oscar J » Thu Sep 10, 2015 6:46 am
Looks good! :)
contegufo
Post by contegufo » Thu Sep 10, 2015 7:06 am
Hi
Your advice has been invaluable! Thank you!
The computer is calculating more images .......
