Render never focus
- thesquirell
Re: Render never focus
You must make sure that your Sun object is dropped inside the box, like on this attached screenshot. When doing so, I got no error messages. Good luck!
I only can second that!thesquirell wrote:Ok, davide, there are tons of things on your scene
david, you need to learn some basic workflow with cindigo, atm there is none...
To have a Sun, you new to activate it! use your C4D sun to define the direction etc, and then drag and drop the sun here: Then create a camera and use the indigo camera tag, otherwise you use the default camera focusing the horizon, set a defined focus point and deactivate autofocus. - C4D isn't suported, the sky is only used for HDRI maps to control the rotation (useless here!)
- Use a phong tag on your statue to smoth the normals!
- Use PT+BiDir instead of MLT!
- None of your fancy C4D materials are suported, use Indigo materials!
- read this tutorial: http://www.indigorenderer.com/documenta ... d-tutorial
**nah... squirell was faster**
Thanks both, Sun object assignment make the difference, after that I discovered C4D Floor object is not recognized from Indigo so substituted it with a normal plane.
Attached the final result, it's noting complicated respect wonderful things I did see in this forum, but a start for me.
I need to learn a lot I know, but my learning path is always with some concrete project in mind.
Hope in the future to became good enough to start something more professional.
- thesquirell
Great steps Davide, now grab that manual and browse through forum, so you can learn more about this amazing piece of artwork(software)!
There's one thing for sure what we need, is VIDEO TUTORIALS!
Anyone wanna help me with that?
Tutorials are a nice idea, but why video and not written?
Video can only be seen linearly, I did always find them time consuming to extract useful info.
Also with a video if you want later to review something you need to look again the whole thing.
I can anyway help for the newbie point of view.
