Indigo Renderer 3.6.6 Beta Release
Re: Indigo Renderer 3.6.6 Beta Release
Post by CTZn » Wed Feb 06, 2013 6:24 am
A good third of my posts is due to an absence of FAQ.
+ 2k+ for a FAQ, I'll be sure to contribute here and there.
radiosity
Post by radiosity » Wed Feb 06, 2013 10:07 am
wonderfull!!!!!and very fast!
radiosity
Post by Zom-B » Wed Feb 06, 2013 10:21 am
CTZn wrote:A good third of my posts is due to an absence of FAQ.
There already is a FAQ online at Support > FAQ ;)
Post by CTZn » Thu Feb 07, 2013 4:05 am
I can't edit it, no wonder that I came to forget about it. I can still submit entries internally.
Post by Pibuz » Thu Feb 07, 2013 8:43 pm
...I don't know if I'm using it correctly but when I try to add a normal map the materials turns out all black
Post by OnoSendai » Fri Feb 08, 2013 1:52 am
Pibuz wrote:...I don't know if I'm using it correctly but when I try to add a normal map the materials turns out all black
Normal maps work fine here.
Post by Pibuz » Fri Feb 08, 2013 1:59 am
..well ok: is there anything I should know before using normal maps? some particular range values, or something like that? I tried with values which worked with the bump map (0.001m) but that didn't work..
I'll post my test in some minutes..
Post by OnoSendai » Fri Feb 08, 2013 2:02 am
Pibuz wrote:..well ok: is there anything I should know before using normal maps? some particular range values, or something like that? I tried with values which worked with the bump map (0.001m) but that didn't work..
All values should be default. scale (b) should be 1.
Post by Pibuz » Fri Feb 08, 2013 3:36 am
..indeed!
With the B value of 1 it works!! Now, testing with different values!
EDIT: values smaller than 1 make the material render black
radiosity
Post by radiosity » Fri Feb 08, 2013 3:49 am
Hi, I set the render resolution to 4000x3000pxl, in 3dmax, but when start the indigorenderer interface, the resolution in 1000x700 as a free version...can you help me?sorry for my poor language
Post by Zom-B » Fri Feb 08, 2013 6:13 am
radiosity wrote:the resolution in 1000x700 as a free version...can you help me?
Is you want to render in higher resolution you need to BUY Indigo first ;)
radiosity
Post by radiosity » Fri Feb 08, 2013 10:39 pm
I BUY IT
I DO NOT SEEM RUDE I WANTED TO ASK YOU SORRY!!!!! BLAME IT is THE MY BAD ENGLISH !!!SORRY, AND THANKS FOR THE ANSWER!!
SORRY FOR MY POOR LANGUAGE!!
RADIOSITY
Juju
Post by Juju » Fri Feb 08, 2013 11:30 pm
whenever I run into problems like that, I always try to reinstall first to see if the problem resolves itself
also make sure you don't have any non-standard characters in the file names, this seems to be a problem from time to time
dakiru
Post by dakiru » Sat Feb 09, 2013 5:33 am
radiosity wrote: I BUY IT
RADIOSITY
Hey, take it easy mate :) I'm pretty sure Zom-B didn't want to insult you in any way. The thing is that 1000x700 is the limitation of demo mode of Indigo. So, in case you've received a license key for you hardware, you have to enter this number to Indigo. Start Indigo > "Help" > "Licensing" > "License keys" tab > enter a proper key for you hardware > OK = Done. These steps unlock the demo mode and no limitations are goind to stand on your way to uberphotorealistic images :)
P.S. There are forums for different languages, check'em out in case you feel expressing yourself better in your mother language.
Post by Pibuz » Sat Feb 09, 2013 5:38 am
You can also post your general questions here, in italian: I'll translate them. I'm sure it's ok, since this forum is more visible and so all the skilled users will see and help..
Puoi anche postare le tue domande generali qui, in italiano: te le traduco io. Sicuramente va bene, dato che questo forum è piu visibile e tutti gli utenti piu esperti vedranno e ti potranno aiutare..
