Blendigo 3.6.5.1
Re: Blendigo 3.6.5.1
Post by StompinTom » Thu Mar 14, 2013 12:14 am
Hi guys,
Any word on the Dupligroup export error? Linked objects work fine, it's just Group instances that are giving up.
William
Post by William » Thu Mar 14, 2013 1:52 am
I think the problem come when section plane feature was implemented, consideration was not taken for empty having no data.
I made a hack, it seems to work if you're desperate, probably it breaks something :wink: .
in export/geomtry.py, find:
		if(obj.data.indigo_mesh.section_plane):
			xml = SectionPlane(obj.matrix_world.col[3], obj.matrix_world.col[2], obj.data.indigo_mesh.cull_geometry).build_xml_element()
			model_definition = (xml,)
			self.ExportedObjects.add(self.object_id, model_definition)
			self.object_id += 1
			return
		# Special handling for sphere primitives
		if(obj.data.indigo_mesh.sphere_primitive):
			xml = SpherePrimitive(obj.matrix_world, obj).build_xml_element()
			self.object_id += 1
			return
Add this before if obj.data != None:
thus;
				self.object_id += 1
				return
				self.object_id += 1
				return
Post by StompinTom » Thu Mar 14, 2013 2:17 am
Hey William,
Nice find. Does it work OK with everything else? Can't afford to break anything at the moment, so if it's not safe yet I'll keep nagging Glare :P
William
Post by William » Thu Mar 14, 2013 2:29 am
I have no idea, use at own risk :mrgreen:
Didn't even make a scene/objects for indigo yet, this bug always in the way of using any assets or using any old scenes from other renderers, just couldn't be bothered making all objects local and duplicates real because this results a mess.
Post by StompinTom » Sun Mar 17, 2013 1:40 am
Some things that could be improved in Blendigo:
- Dupligroups / group instances (NoneType object has no attribute 'indigo_mesh')
- External materials don't seem to work when there is a Blend or Double-Sided Thin material with sub-materials ('no such material as <x>'). I suspect the problem only occurs when there is a sub-sub-material. Seems Indigo saves the first sub-materials in a Blend or Double Sided Thin material, but then doesn't look to see if those sub-materials have any children. Heartless. This may be an Indigo issue with saving materials.
The interface for making materials before was much better, where you could see each material in a stack and could better visualize the material structure.
- Transmittance color needs to be exposed in materials settings (for Double-Sided Thin)
- Depth and Shadow passes need to be exposed in render settings.
- PyNodes are on their way into Blender! Should make Indigo material editing a fair bit easier :)
Post by StompinTom » Tue Mar 19, 2013 9:38 am
PyNodes are merged into Blender trunk:
http://projects.blender.org/scm/viewvc. ... bf-blender
Should make Indigo material setup easier?
William
Post by William » Tue Mar 19, 2013 7:18 pm
This stuff would be great!.... so would a bugfix :cry:
Polinalkrimizei
Post by Polinalkrimizei » Tue Mar 19, 2013 7:55 pm
Should make users of other exporters pretty jealous 8)
Post by OnoSendai » Thu Mar 28, 2013 2:51 am
William wrote:I think the problem come when section plane feature was implemented, consideration was not taken for empty having no data.
			self.object_id += 1
			return
			self.object_id += 1
			return
thus;
				self.object_id += 1
				return
				self.object_id += 1
				return
Nice find, have committed the fix.
SaphireS
Post by SaphireS » Wed Apr 03, 2013 9:49 am
StompinTom wrote:PyNodes are merged into Blender trunk:
Luxrender already got basic pynodes support! :shock:
http://www.luxrender.net/forum/viewtopi ... 962#p94962
Your ad here!
Post by StompinTom » Wed Apr 03, 2013 10:25 am
Awesome! Exactly what would be amazing with Indigo, along with an ISL node.
Perhaps things like Blender clouds and marble textures could be loosely converted to ISL functions?
Post by CTZn » Wed Apr 03, 2013 1:22 pm
From my experience with Maya it's not very difficult to set custom nodes up. The most complex part is the one involving the realtime viewport feedback. I for one skipped that part in MtI.
The rest is about defining inputs and outputs types, names and default values mostly. Then comes the exporting stage wich calls outputs and read them before an eventual data processing.
Sorry if I'm trolling, I'm a fool by night as well ;)
