New double sided thin material - tests
Re: New double sided thin material - tests
Hi Delle,
Good point, I hadn't thought of that.
There will probably be a restriction though that the material on each side can't transmit light. This is so the transmitted component is the same in both directions (front -> back and back -> front). So null materials won't be allowed.
I see, do you think it will be be possible to add a special attribute to a Mesh ("single sided") in order to let it behave as I described? I think it's a modification into intersection code. More or less like you already did for exit portals (they are only visible in one direction).OnoSendai wrote:Hi Delle,
Damn, we almost got one-way mirrors.
I have been waiting for this a long time!
This whole workaround with blending materials and such weren't my bing bang of stuff
Now add a fur/grass generator and I'd find Indigo the all in one solution =D
Cheers,
Roo Evans
Roo Evans
This will be extremely useful!
Even usefull for printed paper like a label on the front of a beer
Good pointZom-B wrote:Even usefull for printed paper like a label on the front of a beer
This lonly bottle waits for double sided mats:OnoSendai wrote:Good point
- zeitmeister
Na denn man Proust!
- wlf_alex
- zeitmeister
Same here!
Since new C4D Exporter now supports the new mats, here is my first test with the double sided material.
I really like the transmittance look of the leaves now
I'm not that satisfied with the C variant atm, but its kind of hard to work with roughness now, and getting a feel for fresnel scale too...
Nice. I haven't played with that material yet
Just another noob question, but where do i find the new material? Just installed 3.6.8, or is it not available for SkIndigo?
24 hours isn't enough
http://www.werkraum3d.com
Not yet, hopefully soon. You can still use it by creating the material with the Indigo GUI and then creating a 'Linked IGM' material in SkIndigo.lape wrote:Just another noob question, but where do i find the new material? Just installed 3.6.8, or is it not available for SkIndigo?
