Glass questions again
Re: Glass questions again
Post by Headroom » Mon Apr 11, 2011 11:10 am
"Indigo has a default ray 'nudge distance' of (I believe) 0.1mm, in order to avoid self-intersections.
So any object around that scale or smaller may not render correctly.
I think the overlap between two objects needs to be larger than that distance to avoid "issues". That is not too difficult to model and given the overall scale of the helix circle object should not be visible in the final render.
scatman
Re: Not so fast....
Post by scatman » Wed Apr 13, 2011 3:47 am
Just when I thought I'd figured it out...the blackness returns! :( This time I'm using beads instead of rods. I've tried some of the earlier suggestions (particularly a gap between beads, no gap between beads, and no gap between beads with 1 bead larger in diameter than the other--of course continuing the Extrude+Scale to center+Remove doubles and Edge Split modifier stuff), but neither works correctly.
see...
Once we figure this out, we need to make a FAQ and include a .blend file with it as an example.
Whoever thinks they actually have a fix for my error, could you please post your .blend file with your reply.
Thanks in advance,
scatman
Post by Headroom » Wed Apr 13, 2011 7:00 am
Send the blend file and we'll have a look at it ;-)
scatman
Post by scatman » Wed Apr 13, 2011 7:11 am
there you go...
FORUM_dnaRna.zip
(2.89 MiB) Downloaded 291 times
Post by Headroom » Wed Apr 13, 2011 2:15 pm
Move the smaller orange half-sphere to the left to get some overlap with the blue half-sphere.
Set the precedence for the:
helix mat to 10
orang half sphere to 20
blue half sphere to 30
From camera.003 you can still see the differnt colors of the two intersecting half-spheres.
From camera.004 you get a greenish color and the black is gone.
I still would recommend to scale al this down from the several meter range to a few centimeters or some nice subtle caustics as in the example below.
dag
Post by dag » Wed Apr 13, 2011 2:25 pm
Gap / intersection should be more than 0.2mm
scatman
Post by scatman » Thu Apr 14, 2011 6:10 am
Thanks Headroom and dag for your help. I tried your suggestion, Headroom. I'm still getting mixed results. When I overlap the 2 rod halves (pill shape) I get a blurring effect where they overlap, if I don't overlap the bead halves, I get more of an exact cut off of the 2 colors. Headroom, can you attach the .blend file from your most resent post? dag, how are you measuring 0.2mm for the overlap?
overlapping rod halves
one rod with overlapping halves and 1 rod with non-overlapping halves...notice some black (might be photorealistic?)
Research continues--file attached,
scatman
Indigo glass against glass TEST.zip
(117.01 KiB) Downloaded 258 times
dag
Post by dag » Thu Apr 14, 2011 7:57 am
With worldscale in blendigo set to 1 x 10^ 0 (default), 1 blender unit is 1 meter, so 0.0002 units is 0.2mm.
I also got gradient blending stuff when overlapping with different precedence.
galinette
Post by galinette » Thu Apr 14, 2011 9:20 am
The gradient blurring is photorealistic. You can force a sharper limit by setting different refractive indexes.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
