Ok I'll hire you to come and do the 2nd click for me then
Are you talking about that? Those looks quite cool. (...I mean quite hot :p)
Even better having this behavior with play/pauseHeadroom wrote:Of course we could also make a Pause/stop button out of the Stop button. First click pauses (Icon changes) and then second click stops.
You could even use space bar as used else(every)where...Zom-B wrote:Even better having this behavior with play/pauseHeadroom wrote:Of course we could also make a Pause/stop button out of the Stop button. First click pauses (Icon changes) and then second click stops.
Without a pause button you don't have button which you might inadvertently mistake with, just a kill button. If you use the space bar to pause as you do for vlc, etc... you can't stop th render as you simply won't click any button by doing so.Headroom wrote:The render/pause (play/pause) may be similar to function in existing applications and because of that may be more intuitive but it still would not address the initial problem, which revolved around the Stop button.
Unless of course I am misunderstanding your proposals entirely.
