How did you manage all that? Just Alt+D?SmartDen wrote:about 500,000 instances
Blendigo for v1.1.13
- aleksandera
- aleksandera
enricocerica
please, give me a sample sceneenricocerica wrote:Hi SmartDen,
Just wonder if you released the final version, I downloaded the available version some days ago and I got the same issues, I mean the UV mapping and the problem with the non applied modifications on the instances.
Thanks
Check normals, dude!
enricocerica
Hi SmartDen,
Here is a zip containing the scene limited to this issue, the image produced with blendigo 1.1.7, blendigo 1.1.13 (current available version) and the UV Maping with the alt-z result.
http://www.myline.be/myline/3D/tests/uvPblm.zip
By the way, the current version has solved the aplly modifications problem. What about the function to limit the materials to the selected objects, the version I downloaded about 10 days ago had this feature, did you removed it due to negative feedbacks ? If so, forget it
Also, should I redefine the mesh light materials ?
Thanks again
Thanks again
Users browsing this forum: No registered users and 72 guests
