Aperture diffraction test 2:
Windows 7 x64, Indigo 2.4.3 x64, Blender 2.49b x64, Blendigo 2.3.3, UAC is off
Image type:
Common sense tells me that image aperture diffraction will not work without aperture image and yes, it doesn't
. Console shows this:
INDIGO EXPORT
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 4235, in buttonEvt
exportStill(defaultFile)
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3375, in exportStill
export(filename, False)
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3323, in export
if exportIndigoScene(filename, objlist, meshlist, matlist):
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3011, in exportIndigoScene
file.write("\t\t\t<path>%s</path>\n"%(relpath(file.name, IndigoUIControls.Camera.ApertureImg.val)))
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 222, in relpath
return utils.getRelativePath(base, target)
File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigopkg\utils.py", line 46, in getRelativePath
raise ValueError("no path specified")
ValueError: no path specified
[1]
Post process: ON
Aperture type: Image
Aperture image: YES (1024x1024, .PNG)
Obstacle map: NO
Works?: YES
Result:
- image_1.png (36.59 KiB) Viewed 5114 times
[2]
Post process: ON
Obstacle map: YES (1024x1024, .PNG)
Works?: YES
Result:
- image_2.png (44.19 KiB) Viewed 5114 times
[3]
Post process: OFF
Obstacle map: NO
Works?: YES
Result:
- image_3.png (49.75 KiB) Viewed 5114 times
[4]
Post process: OFF
Works?: YES
Result:
- image_4.png (76.28 KiB) Viewed 5114 times
Generated type:
Generated settings. Works?:
Blades: YES
Offset: YES
Curvature: YES
Start angle: YES
[1]
Post process: ON
Aperture type: Generated
Obstacle map: NO
Works?: YES
Result:
- generated_1.png (17.13 KiB) Viewed 5114 times
[2]
Post process: ON
Works?: YES
Result:
- generated_2.png (44.29 KiB) Viewed 5114 times
[3]
Post process: OFF
Obstacle map: NO
Works?: YES
Result:
- generated_3.png (30.88 KiB) Viewed 5114 times
[4]
Post process: OFF
Works?: YES
Result:
- generated_4.png (51.84 KiB) Viewed 5114 times
Circular type:
[1]
Post process: ON
Aperture type: Circular
Obstacle map: NO
Works?: YES
Result:
- circular_1.png (12.86 KiB) Viewed 5114 times
[2]
Post process: ON
Works?: YES
Result:
- circular_2.png (48.97 KiB) Viewed 5114 times
[3]
Post process: OFF
Obstacle map: NO
Works?: YES
Result:
- circular_3.png (48.96 KiB) Viewed 5114 times
[4]
Post process: OFF
Works?: YES
Result:
- circular_4.png (60.76 KiB) Viewed 5114 times
Seems like everything works. Great work, dougal2!
