displacement tests thread
Post by Kram1032 » Mon Jun 02, 2008 5:35 am
I now did an image with (hopefully) all the important parts inside... (I used some options which might speed up the render a bit, too)
Edit: Ok, alex was faster^^
if you only want to do a map from a single object, this should be enough ;)
Post by BbB » Mon Jun 02, 2008 9:10 am
Thanks a lot guys.
I'll try now. Blender 246 crashes a lot when playing with nodes.
zsouthboy
Post by zsouthboy » Mon Jun 02, 2008 12:51 pm
BbB wrote:Thanks a lot guys.
That's...odd. I've done a bit with them and never crashed it....
manitwo
Post by manitwo » Mon Jun 02, 2008 1:08 pm
hehe (thanks for the z-buffer tuts ;) )
Post by CTZn » Mon Jun 02, 2008 1:26 pm
I'm finally happy with 1.1.1 !
Map from Maya procedurals, here are the specs:
<tonemapping>
	<linear><scale>0.0003</scale></linear>
</tonemapping>
<material>
	<name>disp_lambert</name>
	<diffuse>
		<albedo_spectrum>
			<rgb>
				<rgb>0.1 0.1 0.1</rgb>
				<gamma>1</gamma>
			</rgb>
		</albedo_spectrum>
		<albedo_texture>
			<uv_set>default</uv_set>
			<path>textures/ASTEROID_Desat_4k.tga</path>
			<exponent>2.2</exponent>
		</albedo_texture>
		<displacement_map>
			<path>textures\ASTEROID_4k.tga</path>
			<exponent>1</exponent>
			<b>0.5</b>
			<c>-0.25</c>
		</displacement_map>
		<bump_map>
			<b>0.01</b>
			<c>-0.005</c>
		</bump_map>
	</diffuse>
</material>
<mesh>
	<max_num_subdivisions>3</max_num_subdivisions>
	<subdivide_pixel_threshold>1</subdivide_pixel_threshold>
	<subdivide_curvature_threshold>-1</subdivide_curvature_threshold>
	<subdivision_smoothing>true</subdivision_smoothing>
</mesh>
Thanx Ono !
edit: actually I'm rendering an higher subd'd one (<max_num_subdivisions>4</max_num_subdivisions>). Indigo prints between 800 and 820Mo on memory.
Higher level (4), no bump mapping
The candidate to displacement:
&quot;That doesn't hurt&quot;, he said, &quot;but the bump mapping is scratching my shape&quot;
zsouthboy
Post by zsouthboy » Mon Jun 02, 2008 2:48 pm
holy - that's really detailed!
Post by BbB » Mon Jun 02, 2008 5:02 pm
Very nice indeed!
Kosmokrator
Post by Kosmokrator » Mon Jun 02, 2008 7:06 pm
r u carzy??????????//
how u get this rock????
its the rock rocking!!!!!
f@#@!!!!
Post by BbB » Mon Jun 02, 2008 7:24 pm
My contribution to the grass discussion. Trying a shabby, unkempt look. Not nearly enough subdivision, but you get the general idea.
Post by suvakas » Mon Jun 02, 2008 8:29 pm
Looks very good (besides those sharp killer strands).
Care to share the D map? :wink: Or if not, then maybe give some pointers?
Did you paint the bright and dark color variations on to the map?
Post by BbB » Mon Jun 02, 2008 8:55 pm
I tried that but it didn't work. So I just looked for a very shabby-looking grass map. The displacement map is just a greyscale version. I haven't even made it tileable yet. Just checked if the idea could work. Here are half-res versions (the full-res maps were too big to upload):
ShabbyGrass.zip
(1.32 MiB) Downloaded 357 times
Post by CTZn » Mon Jun 02, 2008 10:48 pm
Thanks for comments guys, the grass tests are convincing too !!
Kosmokrator wrote:how u get this rock????
The base geometry is
- a cube,
- randomised vertex position,
- subdivided,
- reapeated the two above various times,
- then displaced with some mixed texture. The texture resolution is important too (4k square, ~60Mo (tga)).
Then I'm asking Indigo to subdivide each triangle down to 1 px, but they don't reach that point because a <max_num_subdivisions> of 4 is not high enough for that, and a value of 5 may be overkill for my system. Maybe I could optimize a bit by setting curvature conditions :!: btw I think that curvature value is in radians, need confirmation/infirmation please.
Post by OnoSendai » Mon Jun 02, 2008 11:15 pm
Yes it's radians :)
Post by CTZn » Mon Jun 02, 2008 11:21 pm
Aah thanks :D
dougal2
Post by dougal2 » Tue Jun 03, 2008 12:58 am
Can you write up a full tutorial of how you rendered that displacement ?
Then I can set about sketching routines in MtI to automate the relevant parts ;)
