Camox
by Camox » Thu Sep 06, 2007 2:03 am
you use the old cindigo exporter ! try this :
<background>
<spectrum>
<rgb>
<rgb>0 0 0</rgb>
<gamma>2.2</gamma> <--the line add
</rgb>
</spectrum>
</background>
ciccio
by ciccio » Thu Sep 06, 2007 2:17 am
thanks Camox........thanks Kram1032 for the reply
what is .............."""simply conwert the "piano" object to a poly objeckt""""??????????
ciccio
by ciccio » Thu Sep 06, 2007 2:18 am
excuse me for my English
Labello
by Labello » Thu Sep 06, 2007 2:28 am
i think the greatest favour u could do us is stopping doubleposting... use the edit-button..
2 convert a object to a polyobject just select it in the objectmanager an press c
ciccio
by ciccio » Thu Sep 06, 2007 2:42 am
GREAT
OK
Labello
by Labello » Thu Sep 06, 2007 2:45 am
AND make shure that u use the latest version of cindigo AND indigo!
by fused » Thu Sep 06, 2007 8:47 am
CoolColJ wrote:another question Fuse
Are Polygon selection tags for an object, for assigning material, supposed to work with Cindigo into Indigo?
no
@ciccio:
use the
newest cindigo version !!!
CoolColJ
by CoolColJ » Thu Sep 06, 2007 12:20 pm
Thanks Fuse
well you can split off the parts into new objects to create new material, I guess I'm just uaed to being able to select polygons and assign a material to them in Sketchup
I don't know if you said you fixed the normals issue, ie where Indigo shows a lot of normalising messages. Well the CG Sphere scene, was fine at first, but once I started to split the sphere in half and modify the mesh, all those Indigo normalising message came back!
CoolColJ
by CoolColJ » Thu Sep 06, 2007 5:04 pm
I found another bug -
none of the changes I make to a material's bump map values make any difference. In the IGS scene file it's always at 0.001
Negative or positive values of any type don't register
CoolColJ on Fri Sep 07, 2007 6:30 am, edited 1 time in total.
by fused » Thu Sep 06, 2007 11:24 pm
CoolColJ wrote:I don't know if you said you fixed the normals issue, ie where Indigo shows a lot of normalising messages. Well the CG Sphere scene, was fine at first, but once I started to split the sphere in half and modify the mesh, all those Indigo normalising message came back!
its a know issue (at leas to me
). it happens when you have unused points. use 'optimize'. will find a solution for that
ciccio
by ciccio » Fri Sep 07, 2007 12:14 am
fused wrote:CoolColJ wrote:another question Fuse
no
@ciccio:
use the
thank fused
ciccio
by ciccio » Fri Sep 07, 2007 12:17 am
Fused where is "tag object"" in your release cindigo??
- 1.JPG (62.13 KiB) Viewed 4183 times
ciccio
by ciccio » Fri Sep 07, 2007 12:22 am
where the object??
- 1.JPG (451.64 KiB) Viewed 4182 times
Labello
by Labello » Fri Sep 07, 2007 12:33 am
dude... i beg you please stop the doubleposts...
the object-tag isn't neccessary anymore. and u have to convert your objects into polyobjects as i already told u...
ciccio
by ciccio » Fri Sep 07, 2007 12:52 am
Labello wrote:dude... i beg you please stop the doubleposts...
Thank labello
Sorry
