h
yonosoy
Re: h
Post by yonosoy » Tue May 19, 2020 1:22 pm
yonosoy
Re: h
Post by yonosoy » Mon May 25, 2020 9:57 pm
Re: h
Post by pixie » Tue May 26, 2020 4:52 am
Engel 02.
wow! \o/
yonosoy
Re: h
Post by yonosoy » Wed May 27, 2020 1:00 pm
All this wave fields...
Thank you!
yonosoy
Re: h
Post by yonosoy » Fri May 29, 2020 6:40 am
2 mm diameter is not enough for the first light plane. If the diaphragm is opened, the focus is lost (more over, with other cams).
With the modeled coating, the light pass through 52 mediums only for the cam...
And stop by the moment...
yonosoy
Re: h
Post by yonosoy » Wed Jun 10, 2020 11:49 am
yonosoy
Re: h
Post by yonosoy » Sun Jun 14, 2020 7:40 am
yonosoy
Re: h
Post by yonosoy » Wed Jun 17, 2020 1:44 am
Re: h
Post by OnoSendai » Wed Jun 17, 2020 3:09 am
Looks good, is that with the updated sky model? (e.g. with latest Indigo release)
yonosoy
Re: h
Post by yonosoy » Wed Jun 17, 2020 3:24 am
Yes, it is.
Only a subtle S curve as postproduction. Linear tonemapped EXR.
yonosoy
Re: h
Post by yonosoy » Sun Jun 21, 2020 4:24 am
41.5 millions of instances.
Awaiting for slope (and others) possibilities with the scatter... with patience.
Re: h
Post by OnoSendai » Mon Jun 22, 2020 12:18 am
Ok, adding,
This is a test with the following shader:
def evalCreate(int index, vec3 p) bool :
  normalWS(env).z > 0.8
p.s. excuse me for posting such an ugly image in your thread of beautiful images :) (feel free to remove)
wob
Re: h
Post by wob » Mon Jun 22, 2020 3:45 am
is it indigo rendering result? 41 mln of instances??? how?
indigo seams going into a deepest trance while cinema 4d igs exporting with only 1 mln multi-instances scene - screenshot 1,
with huge memory leaks, screenshot 2.
just add simle cinema 4d scene to try...
1mln instances.zip
(82.85 KiB) Downloaded 344 times
Re: h
Post by OnoSendai » Mon Jun 22, 2020 4:16 am
wob: this is using Indigo scattering, which creates the instances in Indigo itself.
This tends to be a lot faster and use less memory, since it avoids the export process, doesn't try and render previews in C4d, etc..
wob
Re: h
Post by wob » Mon Jun 22, 2020 9:15 am
i know how it works (redshift proxy), but can i use it in cinema 4d in cindigo or it's available only in standalone app? and where is this function avaliable, in which menu?
and why cinema 4d multi-instances dont work like that scattering?
