jarmenkell
Post by jarmenkell » Wed Jul 28, 2010 11:11 pm
comments and tips regarding adding more realism to the picture are highly appreciated.
Post by pixie » Thu Jul 29, 2010 1:28 am
jarmenkell wrote:with bits of anti-grav tech, as i can see))
That's actually a bug in my scene that makes objects levitate :D
Post by lycium » Sun Aug 01, 2010 4:20 am
<3 MLT noise
Post by StompinTom » Sun Aug 01, 2010 4:41 am
lycium wrote:
Displacement works again, then? :D
That's a lot of MLT samples/second! Has it been that fast or have you done another one of your magic speedups?
Post by pixie » Tue Aug 03, 2010 2:42 am
Weird results during precedence test
Precedence
glass 3
ice 2
water 1
and the ice likes to get dark when imersed in water :S
bidir pt
simple pt
scene.rar
scene
(22 KiB) Downloaded 235 times
mlt
Post by CTZn » Tue Aug 03, 2010 3:49 am
The image tagged MLT is in fact MLT+BiDir :)
Can you please state the Indigo version pixie ? Using 2.4.6 I've got different results than yours after redoing the scene with Maya... I don't have 2.4.7 though.
In my scene the container is about 1m wide, water has a precedence of 2, plexi and ice a precedence of 3.
Edit: but yeah I've got a very dark ice cube with glossy transparent too, it gets better if replaced by a specular material (MLT 2.4.4). With glossy used, results have a different response with varying pov. That said the ice cube below IS glossy transparent.
GPU glossy ice 2.4.6
Post by pixie » Tue Aug 03, 2010 4:41 am
CTZn wrote:The image tagged MLT is in fact MLT+BiDir :)
It is 2.4.7 indeed, pt gives a quite different result...
Post by neo0. » Thu Aug 05, 2010 3:43 pm
My first sci fi project with indigo.
Gee, I wonder why it never occured to me that using textures looks so much better than a simple diffuse texture. :)
Post by Zom-B » Tue Aug 10, 2010 7:57 am
Godzilla
Post by Godzilla » Tue Aug 10, 2010 5:51 pm
Yes it would be nice if that bug was addressed... :(
I re-rendered my this old scene. The scale in the old image was off so that the diamond was ~10cm in height :(
This one uses a correct (or at least more realistic) scale.
Post by OnoSendai » Tue Aug 10, 2010 5:56 pm
Zom-B wrote:
OnoSendai wrote:there's an outstanding bug with bidir that gives dark edges on some glass.
I just tried a "glass version" of a CAD model...
MLT, once with & without BiDir. With BiDir renders fast as hell, but the result... well... :roll:
If you need the scene for debugging, just tell!
Hi Zom-b,
Just working on this issue now. I think I have an idea what it is, so hopefully I'll have a fix soon.
nik
jarmenkell
Post by jarmenkell » Wed Aug 11, 2010 8:19 pm
i tried to recreate that beautiful lightwall from Tron: Legacy, but there's a kinda bug or... well, that jagged thing that results from gradient texture. i didn't plan it.
there was another kink with that gradient in "Emission" tab: that wall had 10 height segments, and the gradient was "tiled" on it (instead of being stretched from top to bottom). projection type - UVW mapping.
i "solved" that problem by reducing the count of height segments to 1, but that's not a good solution (i also lost some control of that wall's curviness).
is there something specific that i should know about gradient textures in Indigo?)
Post by zeitmeister » Wed Aug 11, 2010 8:35 pm
Hm,
what host 3d application do you use?
Did you try a 16bit gradient texture?
jarmenkell
Post by jarmenkell » Wed Aug 11, 2010 8:52 pm
Cinema 4D
i'll give it a try, thnx
any ideas about that tiling problem?
dcm
Post by dcm » Thu Aug 12, 2010 1:54 am
I posted this problem with gradients month ago, u need to make 32bit gradient in PS to reduce that bugs :)
