Stochastic Progressive Photon Mapping demo
Re: Stochastic Progressive Photon Mapping demo
Post by lycium » Thu Aug 05, 2010 2:38 pm
I seem to recall in the original GPUSPPM demo that unrolling an object intersection loop gave like a 4x speedup on nvidia cards.
Post by StompinTom » Thu Aug 05, 2010 3:09 pm
lycium wrote:I seem to recall in the original GPUSPPM demo that unrolling an object intersection loop gave like a 4x speedup on nvidia cards.
:? Easy on my poor brain, Thomas! If it was as easy as unrolling crepes then I'd do it in a second.
Post by Borgleader » Thu Aug 05, 2010 3:12 pm
:lol: I dont even know wth you guys are talking about :oops:
Post by lycium » Thu Aug 05, 2010 3:26 pm
from ompf: http://ompf.org/forum/viewtopic.php?f=10&t=1492#p16550
thachisu is toshiya hachisuka, principal author (i think) of sppm.
Post by CTZn » Thu Aug 05, 2010 8:09 pm
You are missing the point lycium, it's all about frenchy pancakes.
:mrgreen:
Talking about wich, it's good to read that you are tweaking MLT !
Post by lycium » Thu Aug 05, 2010 9:28 pm
oh :oops: i've never had a crepe!
here's a further improved mlt result, 20 mins on a 3.2ghz i7:
Post by StompinTom » Thu Aug 05, 2010 11:34 pm
lycium wrote:oh :oops: i've never had a crepe!
This is just MLT on the CPU, right? Looking great!
Post by PureSpider » Fri Aug 06, 2010 2:15 am
CoolColJ wrote:what has changed? I noticed a more multi-coloured look
It does full spectral rendering and motion blur now! :D
Post by Zom-B » Sat Aug 07, 2010 7:54 am
lycium wrote:We've been improving MLT in Indigo quite a lot recently 8)
Quite hard to tell whats the difference.... maybe you can explain a little more :)
CoolColJ
Post by CoolColJ » Sat Aug 07, 2010 3:22 pm
The way SPPM is used in the GPU Luxrender offshoot (I use it with CPU only), you start off with large round photons, and then progressively gets smaller and more defined over time. You set the inital size, amount of photons and then how quickly the photon size decreases each pass
I think Indigo could use a similar format somehow with MLT
ie start with large maxchange value and have it go down progressively?
Maybe have it as an optional switch
That would get around the splotchy look and slow convergence of having small max change values, but also having more accurate details that the small max change values give
CoolColJ
Post by CoolColJ » Sat Aug 07, 2010 3:25 pm
getting the caustics to show in the refracted parts of the glass sphere this early - very complex path
Light through sphere - water - floor - water - refraction through sphere etc
Post by CTZn » Sun Aug 08, 2010 12:35 am
CoolColJ wrote:[...]and then progressively gets smaller and more defined over time. You set the inital size, amount of photons and then how quickly the photon size decreases each pass
Maybe have it as an optional switch[...]
That's one of my early suggestions to Nick, IIRC I was invited to investigate further on the potential. Estimating time frame seems to be the issue here.
Adding a maxchange delta perhaps ? Each mutation would use an arbitrary value within the fixed range, so to discard time concerns... That kind of tweak sounds as experimental as promising.
The way to test its efficiency would be:
A: Render one scene for a fixed duration using a relevant parameter value.
B: Render n times the scene with a variating parameter for duration/n, then merge.
And C: compare visually the merged image in B with the original in A.
burnin
Post by burnin » Sun Sep 12, 2021 12:41 am
Decade later... 9:38 AM · Jul 7, 2021
Post from Otoy, rendered w/ Octane (WIP)
Post by pixie » Sun Sep 12, 2021 7:41 pm
I love these back to the future kind of posts! Thanks burnin! :)
Post by lycium » Sun Sep 12, 2021 10:45 pm
Hope we're all doing ok, nice to see these old topics again :)
