measurement units in cinema
5 posts • Page 1 of 1
jarmenkell
Post by jarmenkell » Sun Jul 18, 2010 8:16 pm
i know that question sounds stupid but still... i'm totally confused(
what measurement units should i have in Cinema and in Cindigo?
if i have millimeters in both of them (more proper from the real-world modelling, i suppose), will it be fine?
or should i use the default meters?
(what confuses me most that when i use meters i end to have glasses of water e.g. 88meters hig - that's not good, i think=)
Re: measurement units in cinema
Post by fused » Sun Jul 18, 2010 8:30 pm
jarmenkell wrote:if i have millimeters in both of them (more proper from the real-world modelling, i suppose), will it be fine?
yes :)
jarmenkell
Post by jarmenkell » Sun Jul 18, 2010 8:38 pm
thank you, fused!
Post by zeitmeister » Mon Jul 19, 2010 6:32 pm
You can model in very scale you want to.
Important is the scene scale factor in the Indigo render settings! So if you model a box which is 200x200x200 c4d-units big, and you intented it being 200 cm large, you simply set your scene scale factor to cm.
Same in mm, m, km.
Feel free with that, but you should always keep realistic proportions in mind, otherwise some materials could cause massive trouble.
jarmenkell
Post by jarmenkell » Mon Jul 19, 2010 11:14 pm
yeah, i've already noticed that, when made a glass table)) it ended up being 4 meter thick, which made it almost absolutely non-transparent
Users browsing this forum: No registered users and 57 guests
