Mist material
Come here for help & support.
chubakueno
Mist material
Post by chubakueno » Wed Jun 23, 2010 2:46 pm
I was trying to get some mist like this:
And I get this material:
As you will see at the base of the sphere the mist material is almost transparent, that's because the paper es above the sphere's base, but the material should be volumetric
And sorry for my poor english :roll: :mrgreen:
edit: Mist material
<medium>
		<name>Unnamed</name>
		<precedence>2</precedence>
		<basic>
			<ior>1.0001</ior>
				<uniform>
					<value>0</value>
				</uniform>
		</basic>
	</medium>
	<material>
		<name>Fog</name>
		<glossy_transparent>
			<exponent>
				<constant>
					5000
				</constant>
			</exponent>
			<internal_medium_name>Unnamed</internal_medium_name>
			<absorption_layer_transmittance>
				<shader>
					<shader><![CDATA[def eval(vec3 pos) vec3 :
	vec3(
if(
dotk(pos)>1.0,
0.0,
add(dotk(pos),0.2)
)]]></shader>
				</shader>
			</absorption_layer_transmittance>
			<layer>0</layer>
		</glossy_transparent>
	</material>
Re: Mist material
Post by StompinTom » Wed Jun 23, 2010 3:14 pm
You need to use an SSS material. So something like IOR 1.0 (doesn't need to refract light) and a Uniform scattering factor of 0.01 or something.
chubakueno
Re: Mist material
Post by chubakueno » Wed Jun 23, 2010 3:20 pm
With 0.0 IOR I get this result:
edit 1.0, but the image is correct
Re: Mist material
Post by StompinTom » Wed Jun 23, 2010 3:38 pm
StompinTom wrote:You need to use an SSS material. So something like IOR 1.0 (doesn't need to refract light) and a Uniform scattering factor of 0.01 or something.
I'm not sure if 0 is physically possible. Mist is basically just light scattering. There's is some refraction, I'm sure, but for all intents and purposes it's just air that's dusty. So scattering does all the work for you.
chubakueno
Re: Mist material
Post by chubakueno » Wed Jun 23, 2010 3:49 pm
Yes, but the floor mist is what I'm trying to achieve and the only way that I have found to do it is with heterogeneus participating media.
Re: Mist material
Post by StompinTom » Wed Jun 23, 2010 4:31 pm
chubakueno wrote:Yes, but the floor mist is what I'm trying to achieve and the only way that I have found to do it is with heterogeneus participating media.
So, instead of modulating the IOR as you move from the bottom up (IOR 1.0 to 0.0), change the scattering instead (0.01 to 0.00) so the higher the mist is, the less it scatters, therefore the clearer it appears. I'm just pointing out what settings make that effect. For fog, the IOR should always stay at 1.0.
Re: Mist material
Post by StompinTom » Wed Jun 23, 2010 4:44 pm
For example:
	<medium>
		<name>mist-medium</name>
		<precedence>10</precedence>
		<basic>
			<ior>1</ior>
				<uniform>
					<value>0.001000</value>
				</uniform>
			<subsurface_scattering>
                                     <shader>
                                      vec3(
                                           if(
                                                dotk(pos)>1.0, 0.0,
                                                add(dotk(pos),0.2)
                                         )]]></shader>
                                    </shader>
				<phase_function>
					<uniform/>
				</phase_function>
			</subsurface_scattering>
		</basic>
	</medium>
	<material>
		<name>mist</name>
		<specular>
			<internal_medium_name>mist-medium</internal_medium_name>
		</specular>
	</material>
Or something like that. Haven't tried it and I'm shit with code, but that's the gist of what I think it may be.
Re: Mist material
Post by Borgleader » Wed Jun 23, 2010 5:11 pm
First error I got was "could not find roor "scenedata"" so i added the <scenedata> ... </scenedata> tags before and after the code.
then i got:
SceneLoaderExcep: Found unexpected element 'shader'. (In element 'scattering_coefficient_spectrum', around line 14, column 13)
Re: Mist material
Post by CTZn » Wed Jun 23, 2010 11:57 pm
Wrong assertion I wrote:Heterogeneous participating media were demonstrated to work with Indigo long ago, but the feature is still not present/exposed in current builds (perhaps for speed concerns ?).
Myself am much anticipating heterogeneous participating media :)
As noted below, Indigo 2.4.3 is exposing the feature.
You also want to avoid specular/glossy volumes to intersect with simple surfaces, as such intersections are opening the volume and therefore do lead to incorrect results. Either reduce the radius of the sphere or move it up in order to manage a space superior to 0.2mm above the ground, for safety.
Re: Mist material
Post by StompinTom » Thu Jun 24, 2010 12:47 am
Borgleader wrote:First error I got was "could not find roor "scenedata"" so i added the <scenedata> ... </scenedata> tags before and after the code.
then i got:
Oh there's no way that I got it perfectly right. I was just showing where I think the shader code should go (what parameter needs to change over the height of the object). He was playing with absorption layer transmittance and IOR, where I was trying to show that it's actually the scattering coefficient he's looking for. My two cents!
Re: Mist material
Post by CTZn » Wed Jun 30, 2010 5:55 am
Hoh, shame on me...
OnoSendaï did introduce heterogeneous participating media with Indigo 2.4.3 ! I bet the shader would be quite "simple".
Still, it's above my head :oops:
Re: Mist material
Post by fused » Wed Jun 30, 2010 6:33 am
CTZn wrote:Hoh, shame on me...
3d fbm decreasing over the z axis (up).
let me do that quickly :)
Re: Mist material
Post by StompinTom » Wed Jun 30, 2010 6:49 am
Yessss. But you stick the shader in the <scattering_coefficient_spectrum> under <value>, right?
EDIT: Tutorials on ISL would be amazing. The reference is probably great for people familiar with that kind of coding, but not so for us mere mortals :)
Re: Mist material
Post by fused » Wed Jun 30, 2010 6:54 am
I think it should absorb a bit, too. otherwise the scattered rays fly around forever.
It has to look like this:
    <medium>
        <name>MedIndigo Material_mid1</name>
        <basic>
            <ior>1.000000</ior>
            <cauchy_b_coeff>0.000000</cauchy_b_coeff>
          <absorption_coefficient>
            <shader>
              <shader>
                <![CDATA[
                   vec3(fbm(pos, 3) * 0.1)
                   #vec3(0.0)
              </shader>
              <wavelength_dependent>false</wavelength_dependent>
            </shader>
          </absorption_coefficient>
            <scattering_coefficient>
              <shader>
                <shader>
                  <![CDATA[
                   #vec3(0.0)
                </shader>
              </shader>
            </scattering_coefficient>
            <phase_function>
              <uniform />
            </phase_function>
        </basic>
    </medium>
Re: Mist material
Post by fused » Wed Jun 30, 2010 7:16 am
nevermind guys... its soooooooooooo slow without LLVM (im on x64), it wont even start rendering.
