Architectural Visualization Study - The Farnsworth House
Re: Architectural Visualization Study - The Farnsworth House
Post by Pibuz » Fri Jun 18, 2010 5:08 am
I guess he modeled them. He's a very good vegetation-ist! :lol:
PowerMax
Post by PowerMax » Fri Jun 18, 2010 4:22 pm
sorry, but since you use the skp I wonder if you use the hdr map, how can you change the sky light so smooth?
Jeff
Post by Jeff » Fri Jun 18, 2010 4:38 pm
dakiru wrote:That's very impressive, Jeff! environment 2c and environment 1c almost look like a good photo. :shock:
Thanks dakiru. For those two images, I used the F250CD camera response function.
Pibuz wrote:Ok jeff. Let's put it on these terms: I'LL BUY YOU THOSE TREES!
Thanks Pibuz!
StompinTom wrote:Some things look a bit too shiny to me, but damn, that environment is looking good! Very natural-looking!
Thanks Tom. I already lowered the exponent value on that grass to 50 but it was still shiny. It must be lowered even further.
Word!
Jeff, where did you get them from? Evermotion, XFrog, Dosch?
The trees were modeled inside sketchup. I would love have those Evermotion trees on the scenes but they are not compatible with sketchup.
Jeff
Post by Jeff » Fri Jun 18, 2010 5:19 pm
PowerMax wrote:sorry, but since you use the skp I wonder if you use the hdr map, how can you change the sky light so smooth?
I use the sketchup sun and sky for most of the renderings on this thread. The color of the sky can be changed under the light layers. To assign layers to the sun & sky, open render settings and choose the environment. Assign layers as shown. (see attachments) During rendering change the values on the sun or sky layer to get desired results.
Cheers!
PowerMax
Post by PowerMax » Fri Jun 18, 2010 5:47 pm
Thank you very~~~~much to tell me how to set the enviriment. person like you to willing to share is rare these day.
By the way, the grass you told I can;t do it right, the website you gave is not very easy to follow, can you show us?
Post by StompinTom » Sat Jun 19, 2010 12:53 am
Try exponent 20 with IOR or 1.6 or a bit lower. It's been working for me but see how it looks...
Jeff
Post by Jeff » Sat Jun 19, 2010 1:26 pm
PowerMax wrote:Thank you very~~~~much to tell me how to set the enviriment. person like you to willing to share is rare these day.
On page 3 of this thread, I uploaded the sketchup file of the environment I am using for the scenes rendered here. It has grasses and trees. You can download it.
Cheers!
Jeff
Post by Jeff » Sat Jun 19, 2010 1:33 pm
StompinTom wrote:Try exponent 20 with IOR or 1.6 or a bit lower. It's been working for me but see how it looks...
Thanks Tom, I'll try those values for the exponent & IOR.
Jeff
Post by Jeff » Mon Jun 21, 2010 1:13 pm
Some updates. Nothing special. Just fixed the grass. It is no longer shiny.
Post by Pibuz » Mon Jun 21, 2010 9:49 pm
Sorry Jeff to bother you.
Do you still achieve half-diffuse grass setting its SU opacity to values different from 100? Because it seems that here the feature is broken or something.
I'll post some tests but if I set a normal plastic and then I select an opacity value different from 100%, the material is rendered just the same.
Jeff
Post by Jeff » Tue Jun 22, 2010 4:57 pm
Hi Pibuz!
Yes, it is still working. I am also using the 50% opacity & dull plastic material preset on the leaves and it is noticeable on some of the foliage on the first set of renders on page 4. I also used it on the grass for the GH house.
Jeff
Post by Jeff » Tue Jun 22, 2010 5:18 pm
Just re-rendered some old scenes again. The only major change here was the elevation of the house. It is much lower now. The first step on the stair is now at the right height from the ground.
Post by Pibuz » Tue Jun 22, 2010 7:31 pm
..strange...
I find the auto-blend when SU opacity is different from 100 working oddly in v.2.2.12. All right in 2.2.9.
I did some tests, I'll post them here in a few days..
Jeff
Post by Jeff » Thu Sep 23, 2010 5:16 pm
I finally had time to restart this WIP. On this update, some of the vegetation had been replaced.
Post by OnoSendai » Thu Sep 23, 2010 5:19 pm
The Vegetation is looking great, well done!
