Indigo Renderer 2.4.4 Beta
Post by lycium » Sun Jun 06, 2010 6:49 pm
Hi all,
Included in this beta release are all the new GUI and core changes so far, except for GPU acceleration support which will be released to the beta testing group shortly. There have been a great many changes, a lot of very new and untested stuff, so this is really a beta release - not recommended for production environments! The biggest changes are to be found in the GUI and single directional path tracing modes.
Single directional path tracing is now much more efficient, and should be preferred over bidirectional in simple illumination settings - reasonably large area lights and limited caustics. In such scenes the rate of convergence is a big improvement over bi-bidirectional, and GPU acceleration further improves this.
The GUI has had a facelift, sporting fantastic new icons made by Godzilla and a number of usability improvements, added features and bugfixes. We've added the ability to easily toggle among the four rendering modes in the GUI, so you can quickly see which is most effective for your scene.
Colour noise has been vastly reduced in this build, at the cost of a small (less than 10%) performance hit. Triangle meshes now use substantially less memory, saving and loading of large IGI files is fixed... see the changelog below for more details, even this list isn't entirely complete!
The BVH accelerator is often faster than kD trees now, especially in exterior scenes. Interior scenes can still be faster with kD trees sometimes, though you might want to tell your exporter to use BVH via the triangle count threshold setting to experiment.
Your testing is greatly appreciated, thanks :)
Windows 32 bit build:
IndigoRenderer_2.4.4_Setup.exe
Windows 64 bit build:
IndigoRenderer_x64_2.4.4_Setup.exe
Mac OSX (32 and 64 bit) build:
indigo.osx.2.4.4_6.zip
Changelog:
2.4.4
* CUDA, OpenCL support (not exposed in this build)
* Indigo components now launch using below normal priority by default
* Many GUI improvements
* BVH, motion blur much faster now, many other localised performance increases
* Lower memory usage for triangle meshes
* Much less colour noise
* Much faster and slightly more accurate sampling
* Much more efficient single directional path tracing
* Fixed saving and loading of large (multi-gigabyte) IGI files
* Fixed image update affecting colour balance
iacx
Re: Indigo Renderer 2.4.4 Beta
Post by iacx » Sun Jun 06, 2010 8:05 pm
Thanks, great work!
dcm
Post by dcm » Sun Jun 06, 2010 10:07 pm
What a nice sunday !
hcpiter
Post by hcpiter » Sun Jun 06, 2010 11:25 pm
Thanks.Great ! good time for some new tests in Indigo !
juan_irender
Post by juan_irender » Sun Jun 06, 2010 11:26 pm
Many thanks, I like interface changes/improvements so much!
dcm
Post by dcm » Mon Jun 07, 2010 2:11 am
why isnt default rgb in light layers 1/1/1? That new RGB values are making pinky GI.
Post by lycium » Mon Jun 07, 2010 2:16 am
In the beginning, there was no light layer colour scaling. Then we added XYZ scaling, but that colour space isn't really intuitive to people, so we changed it to RGB. However, RGB = 1,1,1 gives a different scaling to XYZ in which the image is represented.
So the default RGB colours now are ones that leave the image unchanged in XYZ space, and adjusting in RGB space should work as expected.
Post by suvakas » Mon Jun 07, 2010 2:19 am
-haltspp swtich is not working.
[edit]
-halt also not working.. problems with comman line options?
Godzilla
Post by Godzilla » Mon Jun 07, 2010 3:05 am
Thanks Lycium
First thing i notice is that the icons are getting oddly re-sized which makes them appear blurred..
On the top is my 'altered' version of 2.4.3, and on the bottom is 2.4.4
Post by lycium » Mon Jun 07, 2010 3:11 am
Thanks for the reports guys, I'll get back to this ASAP!
Yoruneko
Post by Yoruneko » Mon Jun 07, 2010 5:08 am
Cool interface. Thanks.
I found some problems.
I got some color noise.
This picture's Render Mode is Path Tracing.
Similar noise with Bi-Directional Path Tracing too.
Is this bug or
Have I made a mistake in the setting?
I added a picture with Aperture diffraction.
[Edit] I deleted a picture with Aperture diffraction because it's already reported.
Caterpillar from test scene.
Merc
Post by Merc » Mon Jun 07, 2010 6:31 am
I can not wait for the GPU version. ))) This version I compared it to Maxwell, Indigo is slower. Perhaps because in Indigo is enabled by default dispersion?
SaphireS
Post by SaphireS » Mon Jun 07, 2010 7:44 am
@Yoruneko: I already posted a bug report here:
http://www.indigorenderer.com/forum/vie ... f=5&t=9808
Besides that, great release! :)
Phoenix
Post by Phoenix » Mon Jun 07, 2010 9:38 am
Yoruneko wrote:Cool interface. Thanks.
Is this bug or
I can confirm this, I ran into the same two problems with this test-scene.
I even rendered a bigger version (1920x1200) and let it run for more than 6 hours to see, how the color noise develops.
http://saved.im/mtcyotc5zxhm/im1275833723.png
Post by fused » Mon Jun 07, 2010 9:52 am
suvakas wrote:-haltspp swtich is not working.
[edit]
Will be fixed in the next release... forgot about the command line parameters :)
