ENSLAVER, could you please share your leaf material!!?!
Yeah, here's the ivy leaf material used http://www.indigorenderer.com/forum/vie ... 115#p97115, it's probably not perfect, uses diffuse_transmitter for fast sss.Jambert wrote:ENSLAVER, could you please share your leaf material!!?!
- ivy_original.pigm
- (559.37 KiB) Downloaded 148 times
Testing some hdri environments with buddha and orange juice ;p
Mat DB!1!ENSLAVER wrote:Yeah, here's the ivy leaf material used http://www.indigorenderer.com/forum/vie ... 115#p97115, it's probably not perfect, uses diffuse_transmitter for fast sss.Jambert wrote:ENSLAVER, could you please share your leaf material!!?!
Nice test render! I guess it took some time to render it because there is no noise on the image.ENSLAVER wrote:Testing some hdri environments with buddha and orange juice ;p
Hmm not long really, maybe 1.5 hours, hdri stuff is pretty quick, specially if there are no super bright points. (phenom x4 9950) Anyway, orange juice has little chunks in it sometimes so the noise doesn't really matter that much =PJeff wrote:Nice test render! I guess it took some time to render it because there is no noise on the image.ENSLAVER wrote:Testing some hdri environments with buddha and orange juice ;p
I tried to upload it, something timed out somewhere, I will try again soon.Soup wrote:Mat DB!1!ENSLAVER wrote:Yeah, here's the ivy leaf material used http://www.indigorenderer.com/forum/vie ... 115#p97115, it's probably not perfect, uses diffuse_transmitter for fast sss.Jambert wrote:ENSLAVER, could you please share your leaf material!!?!
Modeled this yesterday afternoon in between some things and let it render overnight.
14h, 1300spp and still quite noisy :S
EDIT: That might be because of the double-paned windows and loads of grass...
very nice but too much contrast IMHO
I like it. I think the contrast is pretty much on par with an evening photograph. Perhaps from a design perspective it would be good to reduce the brightness of the light under the house making the whole image less contast-y, it kind of draws your eye right away.
ps. Is the background a hdri? Free? Shareable? =P
EDIT: Thought I would go with the evening theme:
Niiiice, I'm a sucker for paper lanterns. The floor is a bit flat, though (har har, isn't it supposed to be?) but the color tones are very nice.ENSLAVER wrote:I like it. I think the contrast is pretty much on par with an evening photograph. Perhaps from a design perspective it would be good to reduce the brightness of the light under the house making the whole image less contast-y, it kind of draws your eye right away.
The background for my rendering IS an HDRI, unfortunately not free
Just for fun. Used some planes with tree alphas for some shadows.
High res here: http://dl.dropbox.com/u/6928552/drainpipe-scene.png
ENSLAVER you rendering rockstar, your tests rule
Quick experiment I did with Sculptris.
~1,350,000,000 tris. (Instanced)
- Borgleader
Can you teach me to be awesome? Pllllllzzzzzzzz
No but seriously, that is realllly cool.
Sculptris is fun!
"bust" with lots of greeble
High res: http://dl.dropbox.com/u/6928552/indigo_ ... _PM%5D.png
