User survey: Testing the water for Blender 2.5
14 posts • Page 1 of 1
dougal2
Post by dougal2 » Sun May 23, 2010 5:18 am
The purpose of this thread is for me to gather some information and opinions about Blender 2.5.
I have a few specific questions, but I'm also open to a bit of open-ended discussion about Blendigo's future.
- Has anyone here started using Blender 2.5 ?
- For any serious work ?
- Would anyone consider adopting blender 2.5 on a more permanent basis if you were able to use Indigo with it ?
- If you're not yet using it, why ? When do you think you'll make the transition (if at all) ?
For anyone who has used blender 2.5 already:
- Is there anything different about your workflow in the new Blender that you'd need the next generation of Blendigo to adapt to ?
- Is there anything particularly you do/do not want carried over from the existing Blendigo paradigm/workflow into an exporter for Blender 2.5 ?
- If a beta-quality or unfinished exporter for Blender 2.5 was made available, would you prefer to use it over the existing Blender 2.4/Blendigo combination ?
- Which features would you miss ?
- Which features are essential ?
Any further comments ? :D
Re: User survey: Testing the water for Blender 2.5
Post by Borgleader » Sun May 23, 2010 5:47 pm
Yes :)
No :(
Of course!
n/a
Blender 2.5 is highly context sensitive and I've gotten used to the panels now being vertical and on the side. Also I believe the scripts window has permanently been nuked. For having played with writing scripts in 2.5 I guess I'd be comfortable with it being split in a few pieces, for example the tab where you define your material settings for indigo could actually appear in the blender material tab and so on. That way if anyone wants to have two sets of materials for doing previews inside blender they can have both sets on next to the other. my 2 cents.
Last time I used blendigo I couldnt get it to export everything in the same file like it used to, is that a design choice or an indigo requirement? Because if possible I'd like to have that option back :)
Most likely
I don't do animations, so not that. I don't use the blur at all, and not really DOF so I guess as long as it does materials a basic settings for environment type, ... I'm all happy.
Materials, basic settings (system, ...)
plaurits
Post by plaurits » Sun May 23, 2010 9:02 pm
I've been using it for modelling since last December.
If student work counts, then yes.
Yes. The only reason I still have 2.49 installed is so that I can use Indigo and other exportes that haven't been ported over yet. I model everything in 2.5 and then opens it in 2.49 and hopes that nothing brakes and then exports.
I can't think of anything specific right now. But the new render api should allow for a much tighter and a much more natural integration with Blender, I hope Blendigo will reflect this as much as possible.
Yes. I would only go back to 2.49 if something in 2.5 didn't work.
Isn't the Cinema 4D exporter pretty good and well integrated? If so, perhaps it could serve as inspiration?
Also, an Indigo material render preview panel inside Blender would be pretty awesome.
sweetcement
Post by sweetcement » Mon May 24, 2010 12:36 am
Like Blender 2.5 better than 2.49 -- only reason I still use 2.49 is Indigo and other exporters, as the others have said. Would probably switch over completely if Indigo exporter was available.
everwind
Post by everwind » Mon May 24, 2010 6:11 am
Yep, I compile it every day and I now only use it (except when I have to use Indigo)
For every work now, so yes (currently I'm making the itsartmag challenge)
Yes of course, I would not use blender 2.49 anymore and that would be perfect !
The new unit system in blender, % of rendersize
I don't really see ...
Maybe yes, maybe not .... yes if the beta version works enough ^^. It's not very cool to have to come back to 2.49 everytime I have to use indigo ...
I don't really understand the use of the buttton 'mesh" and subdivise ... afterall if I want it to be subdivided the "subsurf" button should be enough, no ?
nearly everything on Indigo now. Maybe when the API is fixed it would be cool to have really blendigo integrated in the new shader system and in Indigo :-)
Post by Headroom » Mon May 24, 2010 1:36 pm
I downloaded Blender 2.5 a few days ago and really like the new interface. In my work I have not encountered any of the features that Blender 2.48 has (have never updated to 2.49a) that have not yet been integrated into Blender 2.5.
I would definitely switch to Blender 2.5 if there would be a Blendigo available for it! The fact that there is no Blendigo available for 2.5 is the reason I have not switched yet!
Can't say which feature I'd be missing most, or which I'd like to give up for a beta version. Just present us with a beta and we'll see what you'll get the most complaints for :lol:
Then work like mad to get all the missing stuff integrated.
Heck, every change of direction is associated with some pains. Waiting any longer will just make it more painful!
ENSLAVER
Post by ENSLAVER » Mon May 24, 2010 3:33 pm
I used previous versions of blender for a while, but mostly max. After seeing 2.5 and using it a little I am almost tempted to drop max for the most part.
Doug Armand
Post by Doug Armand » Tue May 25, 2010 9:16 pm
Yes
some
Definately
N/A
Nothing that I've yet come across
I definately need both DoF and Motion blur (both camera and object)
Yes
can't say unless I know what bits will be missing?
Any further comments ? :D[/quote]
Doug
Doug Armand
dougal2
Post by dougal2 » Tue May 25, 2010 10:11 pm
Thanks for all the responses so far, you guys are mostly confirming my suspicions.
The good news is that an exporter for Blender 2.5 does exist, however it is not quite ready enough to be released as a beta. I will try to work towards something that meets your needs over the next month or so :D
Post by pixie » Tue May 25, 2010 10:24 pm
I plan to learn Blender, but only 2.5 afterwards so I won't even touch 2.49.
Post by StompinTom » Wed May 26, 2010 2:05 am
There are only a couple UI issues in 2.5 that are stopping me from using it. That and a couple features, like beveling and stuff. If those are fixed up, I'll have no problem moving over to 2.5.
dougal2
Post by dougal2 » Wed May 26, 2010 3:22 am
StompinTom wrote:There are only a couple UI issues in 2.5 that are stopping me from using it. That and a couple features, like beveling and stuff. If those are fixed up, I'll have no problem moving over to 2.5.
Beveling is now a mesh modifier, like subsurf ;)
Post by StompinTom » Wed May 26, 2010 3:51 am
That was the case in 2.49 though too, but often I use it just to split specific edges to model further and such. Do you know if the bevel modifier still messes up UV mapping? In 2.49 that basically rendered it useless for me...
dougal2
Post by dougal2 » Wed May 26, 2010 3:54 am
oh, um, I don't know, I'll test it with the new exporter some time soon.
Users browsing this forum: Baidu [Spider] and 3 guests
