Jananton
by Jananton » Wed Jan 24, 2007 11:31 am
Hello All,
This is ihmo a simple request...
What I would like to see is the name of the used xml file in the render window title bar. Obviously one needs to do testing on different settings of a scene, and I find myself running often two or three instances of indigo that are all alike, and then I have to search through all commandline windows to check wich is wich...
Greetings from nighttime Amsterdam,
Jan
zsouthboy
by zsouthboy » Thu Jan 25, 2007 3:01 am
++ to this idea too.
Takes a very small line of code to do, too.
by CTZn » Thu Jan 25, 2007 6:56 am
yes, would be usefull; sometimes you can accidentally kill the wrong process... maybe a prompt before closing would be cool (but naming window is better) ?
by OnoSendai » Fri Jan 26, 2007 8:05 pm
Added for next release.
Jananton
by Jananton » Fri Jan 26, 2007 8:54 pm
OnoSendai wrote:Added for next release.
Nice...
Greetings from rainy Amsterdam,
Jan
by CTZn » Tue Feb 13, 2007 11:32 am
See how I'm working (all read
2i_Indigo_phase2d.xml),
actually what would be just perfect is the number of the image only in the tittle, in the fashion im1171267265.png...
[edit] Better, name of the scene (full path is too long for readability) and img#.
Also what about named logs ? That could be a switch (use log.txt located in root folder or im1171267265.txt in "logs" folder).
Should I make a special request for that ?
Hard week in perspective, have fun everyone and don't let anyone push you
Thx OnoSendaï !
