Cindigo 2.2 Stable
Re: Cindigo 2.2 Stable
Post by fused » Fri Jan 08, 2010 9:07 am
PureSpider wrote:To better imagine it: it works just like C4D's own infinite light 8)
indeed!
Rafaello
Post by Rafaello » Fri Jan 08, 2010 3:05 pm
Got it!!!!
Thanks works insanely great.
a.manca
Post by a.manca » Fri Jan 15, 2010 5:15 am
fused wrote:
a.manca wrote:A curiosity: how do you make the mac version?I imagine that the code is the same in both versions...(windows and mac versions)...So, if I know the code of the windows version can I compile it and make a .dylib ?
Basically, yes :)
Thanks fused. Exscuse me! I saw your answer in this moment...so I have Xcode (because I want to program for iphone) and I can compile a .dylib using Xcode. But I don't know how to do that :( And I don't know how to know the code of the plugin for windows! How do you do the mac version of cindigo?
Phoenix
Post by Phoenix » Fri Apr 16, 2010 1:25 am
@fused:
Does Cindigo 2.2 Stable still work with the shortly released Indigo 2.4.3?
Or do we have to wait for an update?
If it works (partly?) what do we have to pay attention?
Kind regards,
Tom
Post by pixie » Fri Apr 16, 2010 2:08 am
Phoenix wrote:@fused:
Kind regards,
Tom
AFAIK there's no major changes nor any backward compatible problems
Post by Zom-B » Fri Apr 16, 2010 3:08 am
2.4.3 works fine so far.
Some new features that "need" integration into Cindigo are:
- starting Indigo with network manager on export
- Adding wait_for_slave_frames_on_stop option to renderer_settings
- -thread_priority now changes whole process priority, so cindigo workaround isn't needed anymore
- control for verbose flag to control some output
- control for not caching kdtree to disk if less than N triangles
Post by zeitmeister » Fri Apr 16, 2010 5:07 am
- animation export for mac
- the ability to save both IGI and IGS into the same defined output folder
Phoenix
Post by Phoenix » Sun Apr 18, 2010 1:05 pm
Okay, thanks for the disclosure! :wink:
CoolColJ
Post by CoolColJ » Mon Apr 26, 2010 1:37 pm
I think this is a bug?
SceneLoaderExcep: Error while parsing DiffuseTransmitter material: ComplexIORExcep: ComplexIORDataSetExcep: Failed to open file 'G:\Renderers\INDIGO v2\nkdata/nkdata/Au.nk' for reading. (In element 'phong', around line 106, column 9)
Indigo version: Indigo Renderer v2.4.3, Windows 32-bit Release
this is what I see in the saved scene file
removing one of the "nkdata" fixed it
<material>
<name>particles_mid3</name>
<phong>
<nk_data>nkdata/nkdata/Au.nk</nk_data>
<ior>1.400000</ior>
<diffuse_albedo>
although it might be a bug in the material itself. I downloaded it from the database. Or a Cindigo translation bug
also when importing these packed IGM files that have multiple entries of blends and what not, do I have to assign all the parts of the material to the object or just the base material item?
Post by fused » Mon Apr 26, 2010 1:49 pm
CoolColJ wrote:I think this is a bug?
<material>
<phong>
<ior>1.400000</ior>
<diffuse_albedo>
yep, cindigo bug :)
just the root material. I really want to rewrite the indigo material in c4d (to make blending easier/to get rid of the mess of blend materials) but I dont really have the time for it :(
CoolColJ
Post by CoolColJ » Mon Apr 26, 2010 1:52 pm
Also Cindigo doesn't seem to be exporting the tone mapping settings.
There is no entry of it in the scene file, even though you can set it in the plugin
edit - might be a user error, since I rendered with the perspective view and not camera selected....
CoolColJ
Post by CoolColJ » Mon Apr 26, 2010 2:13 pm
Everytime I try to put this material on an object and export/render it, Cindigo crashes :(
http://www.indigorenderer.com/materials/materials/327
it makes heavy use of ISL and displacement etc
It even crashes if the material is not applied to an object
Post by fused » Mon Apr 26, 2010 6:12 pm
CoolColJ wrote:Also Cindigo doesn't seem to be exporting the tone mapping settings.
yep, thats a user error :)
CoolColJ wrote:Everytime I try to put this material on an object and export/render it, Cindigo crashes :(
ill look into it :)
thanks for reporting
CoolColJ
Post by CoolColJ » Thu Apr 29, 2010 1:39 pm
I discovered another issue
if I set the viewport to the editor camera and export the scene out to render Indigo complains about focus distance being at zero, even though autofocus is turned on
<focus_distance>0.000000</focus_distance>
when I switch back to the real scene camera and export, it's fine since there is a value there.
Post by fused » Thu Apr 29, 2010 2:25 pm
CoolColJ wrote:I discovered another issue
when autofocus is turned on, indigo determines the distance to the closest object, regardless of what is set in the xml.
does focus distance 0 give you an error? if not i'll just ignore it :lol: ^^
