Post by Pibuz » Fri Apr 09, 2010 5:39 am
Very cute!
dakiru
Post by dakiru » Fri Apr 09, 2010 5:49 am
ENSLAVER wrote:Something else. I will probably resume the render to get rid of that little bit of noise if I find time. No postwork.
Nice colors, such a positive image :)
Post by neo0. » Fri Apr 09, 2010 6:01 am
12,000 spp, rendering overnight is now more possible since my video card doesnt use that much power. :)
Post by Whaat » Fri Apr 09, 2010 6:37 am
neo,
A more interesting ground material would add a lot to your renders. Even just a simple wood table.
Post by neo0. » Fri Apr 09, 2010 6:55 am
Whaat, I meant for the ground material to be neutral but I will look into it.
ENSLAVER
Post by ENSLAVER » Sat Apr 10, 2010 4:15 pm
Copper ball, random.
dakiru
Post by dakiru » Sun Apr 11, 2010 12:59 am
Reworked the old scene a bit. 8800spx/81.5h/MLT+BiDir and a soft noise reduction
Such a big render time is due to the carpet - 17000 instances of the mesh with 1632 faces. A heavy instanced try of getting a sheep wool :)
Post by Pibuz » Sun Apr 11, 2010 3:25 am
dakiru wrote:A heavy instanced try of getting a sheep wool :)
Well, you made it! :!:
..but man: ivy inside a room? That is quite LOLling!
Post by Borgleader » Sun Apr 11, 2010 3:29 am
I love the env map :o
Godzilla
Post by Godzilla » Sun Apr 11, 2010 3:39 am
Sunlight is coming from the wrong direction...
dakiru
Post by dakiru » Sun Apr 11, 2010 3:59 am
Pibuz: Yes, only possible in CG :wink:
Borgleader: It's not - it's a panoramic image on the surface
Godzilla: I was sure, that somebody will spot it :mrgreen:
dakiru
Post by dakiru » Sun Apr 11, 2010 4:32 am
Now it's more correct, except the ivy.. :mrgreen:
Godzilla
Post by Godzilla » Sun Apr 11, 2010 4:42 am
Nice, but couldn't you have just reversed the environment image?
dakiru
Post by dakiru » Sun Apr 11, 2010 4:50 am
Godzilla wrote:Nice, but couldn't you have just reversed the environment image?
That's true, but than I'll have to re-render for 85 hours and there are trees on the opposite side of the environment image. Yes, here is a lack of that sunlight...
Post by Borgleader » Sun Apr 11, 2010 5:02 am
dakiru wrote:Pibuz: Yes, only possible in CG :wink:
:o learn something new everyday. Thanks dakiru! :)
