Very cute!
Nice colors, such a positive imageENSLAVER wrote:Something else. I will probably resume the render to get rid of that little bit of noise if I find time. No postwork.
12,000 spp, rendering overnight is now more possible since my video card doesnt use that much power.
neo,
A more interesting ground material would add a lot to your renders. Even just a simple wood table.
Whaat, I meant for the ground material to be neutral but I will look into it.
Reworked the old scene a bit. 8800spx/81.5h/MLT+BiDir and a soft noise reduction
Such a big render time is due to the carpet - 17000 instances of the mesh with 1632 faces. A heavy instanced try of getting a sheep wool
Well, you made it!dakiru wrote:A heavy instanced try of getting a sheep wool
..but man: ivy inside a room? That is quite LOLling!
- Borgleader
Sunlight is coming from the wrong direction...
Pibuz: Yes, only possible in CG
Borgleader: It's not - it's a panoramic image on the surface
Godzilla: I was sure, that somebody will spot it
Now it's more correct, except the ivy..
Nice, but couldn't you have just reversed the environment image?
That's true, but than I'll have to re-render for 85 hours and there are trees on the opposite side of the environment image. Yes, here is a lack of that sunlight...Godzilla wrote:Nice, but couldn't you have just reversed the environment image?
- Borgleader
dakiru wrote:Pibuz: Yes, only possible in CG![]()
