Blendigo 2.3.x test releases
dakiru
Re: Blendigo 2.3.x test releases
Post by dakiru » Sat Mar 20, 2010 1:47 am
Aperture diffraction test:
Windows 7 x64, Indigo 2.2.12 x64, Blender 2.49b x64, Blendigo 2.3.2, UAC is off
BTW, Blendigo 2.3.2 shows the "Broken installation", but still loads and works.
Console shows this:
Compiled with Python version 2.6.1.
Warning: could not determine argv[0] path
Checking for installed Python... got it!
BLENDIGO v2.3.2
  Windows-platform     : win32
  os.sep               : \
  matdbPreviews        : D:\SET\blender-2.49b-x64\.blender\scripts\blendigopkg\matdb\previews
  assetsPath           : D:\SET\blender-2.49b-x64\.blender\scripts\blendigopkg\assets
  matdbDownloads       : D:\SET\blender-2.49b-x64\.blender\scripts\blendigopkg\matdb
Now Blendigo allows to test only Post Process AD, because when Post Process is ON , Blendigo writes this into the .IGS
<post_process_diffraction>true</post_process_diffraction>
But when the Post Process is OFF, Blendigo writes nothing to .IGS about this setting, so there no <post_process_diffraction> tag at all. In the Indigo Technical reference is stated this:
If true, aperture_diffraction is simulated using a filter applied to the image buffer, instead of perturbation of
rays. This technique is generally faster and less noisy, but slightly less accurate.
type: boolean
default value: true
So, when nothing is written in the .IGS about the post process setting - it's automatically ON.
Here are the results of the Post Process AD test:
[1]
Post process: ON
Aperture type: Image
Aperture image: NO
Works?: NO
Console says:
Export Still to C:\Users\dakiru\AppData\Local\Temp\default.igs
INDIGO EXPORT
  File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 4199, in buttonEvt
    exportStill(defaultFile)
  File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3376, in exportStill
    export(filename, False)
  File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3337, in export
    if exportIndigoScene(filename, objlist, meshlist, matlist):
  File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3026, in exportIndigoScene
    file.write("\t\t\t<path>%s</path>\n"%(relpath(Blender.sys.dirname(IndigoPath.val), IndigoUIControls.Camera.ApertureImg.val)))
NameError: global name 'IndigoPath' is not defined
[2]
Post process: ON
Aperture image: YES (1024x1024, .PNG)
Works?: NO
Console says:
INDIGO EXPORT
[3]
Post process: ON
Aperture type: Generated
Obstacle map: NO
Works?: YES
Result:
[4]
Post process: ON
Obstacle map: YES (1024x1024, .PNG)
Works?: PARTLY
Blendigo doesn't write the <obstacle_map> tag into the .IGS
So, the result is the same as without it.
[5]
Post process: ON
Aperture type: Circular
Obstacle map: NO
Works?: YES
Result:
[6]
Post process: ON
Works?: NO
Console says:
INDIGO EXPORT
  File "D:\SET\blender-2.49b-x64\.blender\scripts\blendigo.py", line 3031, in exportIndigoScene
    file.write("\t\t\t<path>%s</path>\n"%(relpath(Blender.sys.dirname(IndigoPath.val), IndigoUIControls.Camera.ObstacleMap.val)))
dougal2
Post by dougal2 » Sat Mar 20, 2010 2:45 am
Thanks for the report dakiru, that's quite useful and I should be able to fix these errors easily. :)
dakiru
Post by dakiru » Sat Mar 20, 2010 3:00 am
dougal2 wrote:Thanks for the report dakiru, that's quite useful and I should be able to fix these errors easily. :)
Great it helps :) Thank you for your work!
Jambert
Post by Jambert » Tue Mar 23, 2010 10:24 pm
Hi doug, would be nice if animation rendering starts when first frame is exported instead of waiting the end of export
thx
dougal2
Post by dougal2 » Mon Mar 29, 2010 3:04 am
The next release will come soon and will fix the Aperture Diffraction problems reported by dakiru.
The 'Broken Install' error is not yet fixed, but the next release will improve the error message so that I can get a better idea of what is going on.
If there's nothing else reported, I will try to get 2.3.3 out in the next few days.
Post by StompinTom » Mon Mar 29, 2010 6:43 am
Jambert wrote:Hi doug, would be nice if animation rendering starts when first frame is exported instead of waiting the end of export
thx
Also, it'd be great if only objects with a track (location, rotation, scaling) got exported every frame, otherwise they get exported once so that you don't have 3000 copies of the same hi-poly couch bogging down your system. Making arch. viz animations would be much easier that way :)
Looking forward to the next release! Been retardedly busy lately...
dougal2
Post by dougal2 » Mon Mar 29, 2010 6:51 am
@Tom
I don't think the situation regarding animated meshes is quite that simple - what about meshes that deform but don't otherwise move/scale/rotate ?
I'll see what I can do to detect various mesh animations, because I think it would be a worthwhile optimisation.
Post by StompinTom » Mon Mar 29, 2010 7:04 am
dougal2 wrote:@Tom
True say... Maybe a simple option, for now, of toggling a static/dynamic setting per object? If it's static, it will take it's state at whatever frame it starts with and uses that, if it's set to dynamic then it'll export every frame?
I think all deformations also have some sort of track so it can be keyframed. However, hooks and constraints could be a bit different...
PowStudios
Post by PowStudios » Tue Mar 30, 2010 11:21 pm
One other thing: the <step_blend> option is not available in Blendigo Material Tab (using BLEND material).
Cheers,
Pow
MacBook 2.4Ghz, 2GB + i7-920, 6 GB
My MacBook 'whines': http://www.google.com/search?q=macbook+whine
If anyone has a solution that works pls message!
dougal2
Post by dougal2 » Sun Apr 18, 2010 3:16 am
UPDATED TO 2.3.3
DOWNLOADS
WINDOWS: http://www.indigorenderer.com/dist/expo ... taller.exe
LINUX: http://www.indigorenderer.com/dist/expo ... 3.3.tar.gz
Fixed in this release:
* Improved startup error reporting - Please report any new initialisation errors !
* Fixed AD post process switch
* Fixed AD image file paths
* Allow obstacle map with AD Image type
* Fix ValueError: on property "network.wm"
* Tied camera focus distance to blender's DofDist
* Clean up camera focusing UI
* Sync render resolution both ways between Blendigo and Blender
* Fix various bugs with custom output path, IGI saving and EXR output options
* Pass command line options to linux launcher script
Godzilla
Post by Godzilla » Sun Apr 18, 2010 3:21 am
Thanks Dougal!
Post by StompinTom » Sun Apr 18, 2010 4:43 am
Thanks! Off to test...
dakiru
Post by dakiru » Mon Apr 19, 2010 10:51 pm
Hi, dougal2,
I get this, when I start Blendigo:
Console shows this:
BLENDIGO v2.3.3
Initialisation error: DLL load failed: The specified module could not be found.
  os.sep               : \
Windows 7 x64, Blender 2.49b x64, Blendigo 2.3.3
btw, camera focusing UI looks a lot better!
dougal2
Post by dougal2 » Mon Apr 19, 2010 11:15 pm
@dakiru
Just a thought... are you using a 32bit python installation with the 64bit Blender ? That could be the source of the problem.
If not, try first a 32bit Blender, then try a 64bit python install.
dakiru
Post by dakiru » Mon Apr 19, 2010 11:55 pm
I have python-2.6.5.amd64 installed and the Python console shows this:
Python 2.6.5 (r265:79096, Mar 19 2010, 18:02:59) [MSC v.1500 64 bit (AMD64)] on win32
Do I have to uninstall Python x64 and change it for x86, than try Blender x86?
Because now, with 64-bit Python, Blender x86 shows this in console:
Compiled with Python version 2.6.2.
'import site' failed; use -v for traceback
Checking for installed Python... No installed Python found.
Only built-in modules are available.  Some scripts may not run.
Continuing happily.
BLENDIGO v2.3.3
Initialisation error: No module named httplib
  os.sep               : \
  matdbPreviews        : E:\blender-2.49b-windows\blender-2.49b-windows\.blender\scripts\blendigopkg\matdb\previews
  assetsPath           : E:\blender-2.49b-windows\blender-2.49b-windows\.blender\scripts\blendigopkg\assets
  matdbDownloads       : E:\blender-2.49b-windows\blender-2.49b-windows\.blender\scripts\blendigopkg\matdb
Locked
Users browsing this forum: No registered users and 66 guests
