Hi all !!!
I think i am asking too many questions but this one is simple for you, i am sure... I want to use grass material but i couldnt get any result.
Material: http://www.indigorenderer.com/materials/materials/14
I dont know to which type of mesh should i apply this material but i am creating a box and then adding this material on it and i get this result... There are Diffuse and Opacity maps in this material, should i apply displacement map also?
Whats the trick of creating a grass scene like all you do ? (for example Godzilla's Concrete Garden artwork)
Thank you,
Regards
Grass Material
Grass Material
- grass.jpg (49.48 KiB) Viewed 8026 times
Re: Grass Material
Most of the times, Godzilla and other pros use some modeler's native scattering tool to achieve a non uniform distribution of some kind of object, like a grass strand, in this case. So the effect you're aiming to is triggered by the scattering of a sinlge tridimensional object, spread around randomly. Basically, the way to handle such a huge amount of geometry is not allowed by sketchUp's architecture, so we SU user must find another way.
The "clip" materials use an opacity map (black and white) to "cut" part of textures from the objects they're applied to. In this case, a texture with a group of grass strands takes the place of single grass strands: all you have to do is map the original texture onto a simple surface and scatter it instead of the separate 3D objects. You don't need to have a volume, a box or anything: a simple rectangle will do the job. For the first tests keep the mat as simple as possible: a diffuse shader for instance.
Let us know of your progresses!
Re: Grass Material
Swap your blend materials inside IndigoBlend (drag Mat1 over Mat2 and pick "swap"). Currently everything around the grass blades is visible, you probably want it the other way around. Or use material linking.
Re: Grass Material
Thank you for your replies guys, i did what you told me and i think it is ok now... Please check this
I created a "nearly 2D" 3D object, linked the material and then used Maxigo Scatter, used Random Scale and Random Rotations...By the way this scatter tool gives me inspirations
Very nice tool !!!
Is it ok?
Is it ok?
- grass.jpg (328.74 KiB) Viewed 7982 times
- grass max.jpg (37.36 KiB) Viewed 7976 times
Users browsing this forum: No registered users and 109 guests
