Post by neo0. » Sat Mar 20, 2010 7:49 am
Nice test! although there seem to be some compression artifacts on the bottom and the shadows seem to be missing..
PowStudios
Post by PowStudios » Sat Mar 20, 2010 9:32 am
Godzilla wrote:Well, I like my test renders look somewhat presentable :)
Thanks, good to know. Because I intended to ask if this (1) picture is too noisy for 826 s/p. I'll let it render a couple of hours more. I thought 10k s/p is sufficient and there is not much happening later.
Of course a studio render is different to a more or less indirect interior shot. But sometimes I think a picture will not 'converge' anyhow long i will let it cook. In reasonable timespans of course.
(1) In-between Rooms @ 827 s/p
Pow
ps. I know that 827 == 0.8K
Too noisy for 827s/p ?
MacBook 2.4Ghz, 2GB + i7-920, 6 GB
My MacBook 'whines': http://www.google.com/search?q=macbook+whine
If anyone has a solution that works pls message!
Post by lycium » Sat Mar 20, 2010 4:44 pm
ohhh lawdy, that oj looks really nice godzilla :) thx for baking it to look so presentable; faster sss is on our agenda!
Godzilla
Post by Godzilla » Sat Mar 20, 2010 5:23 pm
The reason it took so long to render was mainly due to the SSS material... your render however does not appear to have any complicated materials, so yes, that does look a little noisy for 826 S/p in my opinion...
There are several ways you can speed up rendering of this scene:
Use Exit Portals
Use gray instead of white materials
Add a few more lights
Use a different rendering method
Upgrade your CPU (Just curious, what kind do you currently have?)
Post by Zom-B » Sat Mar 20, 2010 10:02 pm
lycium wrote:faster sss is on our agenda!
niiiiiiice
PowStudios
Post by PowStudios » Sat Mar 20, 2010 10:50 pm
Use Exit Portals
Yes, used 4 Exit-Portals on each side, because it's a four-sided room, 1000x500
Will try different rendermethod
CPU is a i7-920, 6GB
Here is how it came out during the night. I might open up my own thread.
Thanks for the comments,
Pow
5627 s/p, camera mapping, default render settings
Post by CTZn » Mon Mar 22, 2010 2:19 pm
It's ok pow, a bit edgy to me but looking nice.
testing testing, will push further:
procedural textures and tree
Silmä
Post by Silmä » Mon Mar 22, 2010 7:36 pm
Is that tree all geometry? How many gazillion polygons?
Post by CTZn » Tue Mar 23, 2010 12:10 am
I had a willow in mind but used no reference...
1.25 millions triangles, up to x4 by Indigo subdivisions. Planar leafs are folded by displacement, each is originally done of 3 longitudinal faces (no texture clip).
Scene done on a 32 bit system from 2003 (rendering 1h50 @ 75% CPU ressources). I'll have my new pc back in a few days, I'm flirting with memory limits actually.
dcm
Post by dcm » Tue Mar 23, 2010 3:21 am
early morning light study.jpg (959.29 KiB) Viewed 4347 times
Post by zeitmeister » Tue Mar 23, 2010 6:01 am
Wow!
dcm
Post by dcm » Wed Mar 24, 2010 7:59 am
Single MLT, 8 hours on i7 running on stock freq without EPs
PowStudios
Post by PowStudios » Wed Mar 24, 2010 9:05 am
dcm wrote:Single MLT, 8 hours
Hi dcm,
Single MLT means no BiDir ?
Pow
edit: great render
dcm
Post by dcm » Wed Mar 24, 2010 9:36 am
yes 2k MNoCR and single MLT. 8hr is too long imho, will try mlt bidir 2morrow
Gogauss
Post by Gogauss » Wed Mar 24, 2010 2:14 pm
Hi! This is my first contribution to Indigo's forum, though i've been following it for month now!
Just a simple scene to play with lights, hope you like it!
lighting balls.jpg (108.53 KiB) Viewed 4080 times
