Blendigo 2.3.x test releases
Re: Blendigo 2.3.x test releases
I haven't yet addressed many issues in this thread. I hope that towards the end of this month I will have some time available to make another release.
- Borgleader
Is it possible to just use an older version of the script or perhaps manually fix it?
Yes, use 2.2 stable instead.Borgleader wrote:Is it possible to just use an older version of the script or perhaps manually fix it?
- Borgleader
Alright thanksdougal2 wrote:Yes, use 2.2 stable instead.Borgleader wrote:Is it possible to just use an older version of the script or perhaps manually fix it?
For anyone still experiencing the above error message, I would like to know what the error message printed on the console says.Doug Armand wrote:Error%nBroken installation of Blendigo, please reinstall
Abort
The error is supposed to occur if blendigo cannot find any of its sub-module code, but if it works properly after the error message then something is not right.
(Did you guys install 2.3.x alongside a 2.2 stable?)
Interesting that Blender seems to reload the script window on the undo event. Sorry, that 'feature' is not my fault, but if you keep getting these errors I think your installation is broken.Doug Armand wrote:I'm sure you know this already but that irritating error:
Error%Broken installation of Blendigo, please reinstall
Abort
occurs everytime I use undo in blender, if you have a few steps to undo it fires off for each one - it's f*%king irritating
EDIT: This is likely a windows UAC problem, a potential solution is to install blendigo in your home folder, and not inside 'Program Files'
All these will be fixed in next release:
I require further information about these:
StompinTom wrote:There is no toggle to switch between post-process aperature diffraction and true aperature diffraction...
StompinTom wrote:- Even when exporting without Sun/Sky enabled, Sun and Sky lightgroups appear. The IGS file has Sun and Sky lightgroup definitions everywhere, between materials, then again after materials, etc.
dag wrote:If you hit the mesh or material tab 2 times, it switches back to the window you previously were in, but the buttons stay pressed.
the 1st light layer will always be named 'Environment' so that the background colour has its own layer. The 'default' layer, sun, sky and all custom layers will follow after this one.In that case, I shall name the first layer 'environment'
StompinTom wrote:Problems with circular aperature shape here as well.
EDIT: updated to 2.3.3, see next page
[quote="dougal2"MOD EDIT: removed due to update[/quote]
Great, thank you, right in time
Thanks!dakiru wrote:Great, thank you, right in timedougal2 wrote:MOD EDIT: updated
I'll try to post an example of circular aperature shape not working if I have some time...
Shit, well:
Tips? I need to revert back to the previous version because I need to render a lot of stuff tonight.
BLENDIGO v2.3.2
Windows-platform : win32
os.sep : \
matdbPreviews : C:\Users\Tom\Documents\Utilities\Blender 2.49b\.blender
\scripts\blendigopkg\matdb\previews
assetsPath : C:\Users\Tom\Documents\Utilities\Blender 2.49b\.blender
\scripts\blendigopkg\assets
matdbDownloads : C:\Users\Tom\Documents\Utilities\Blender 2.49b\.blender
File "<string>", line 1, in <module>
File "C:\Users\Tom\Documents\Utilities\Blender 2.49b\.blender\scripts\blendigo
.py", line 4435, in <module>
readWriteSettings(0)
.py", line 3406, in readWriteSettings
readWriteValue(d, 'aperture_pproc', IndigoUIControls.Camera.AperturePProc, w
rite, 0)
AttributeError: class Camera has no attribute 'AperturePProc'
Tom,
Are you loading an existing scene ?
Yes'm. Just switching up from 2.3.1, I guess.dougal2 wrote:Tom,
It is too late now for me to debug the error properly (gone midnight already
). I can't see any errors in the code, but I will have to do some testing with loading/saving scenes between blendigo versions; probably tomorrow or over the weekend.
If you're on a deadline and 2.3.2 is still not working, I suggest you go back to either 2.3.1 or 2.2 stable for now.
(I removed the 2.3.1 download links, but if you look carefully at the 2.3.2 link you should be able to figure out how to get it; the files are still on the site and can be downloaded).
All good, I still had the 2.3.1 installed kicking around so I'm back in business! As always, your hard work is much appreciated!dougal2 wrote:It is too late now for me to debug the error properly (gone midnight already). I can't see any errors in the code, but I will have to do some testing with loading/saving scenes between blendigo versions; probably tomorrow or over the weekend.
