I love the second render, heavy caustics involved ! Good balance of colors too. The first lacks readability because objects lines are merged.
Welcome pow !
Welcome pow !
Thanks a lot guys!
dakiru: I was going for a countryside feel for the scene, I'm glad to here that!
neoo: I noticed that one too. I tried making it brighter in photoshop but other portions of the image get too bright. So I just left it that way.
Nice renderings you got there Pow! The 2nd image is great. If you can make it a two point or one point perspective, it would be much nicer.
- PowStudios
Thanks a lot for your comments, guys! I really appreciate. I'll try to refine my models and the materials and will have a look on the color values.
Jeff: Thanks for the pointer. Haven't read about that before (http://en.wikipedia.org/wiki/Perspectiv ... erspective)
Here is another one I rendered tonight.
Greets,
Pow
p.s. sorry for the long filename, I was a bit drifted from the whine
Good Website!
Greets,
Pow
- Desk topview
- sofacloth_topdesk_5813spp_WEB.jpg (304.61 KiB) Viewed 5119 times
MacBook 2.4Ghz, 2GB + i7-920, 6 GB
My MacBook 'whines': http://www.google.com/search?q=macbook+whine
If anyone has a solution that works pls message!
Little still life
- scen1.jpg (201.82 KiB) Viewed 4996 times
- scen1_cam.jpg (219.88 KiB) Viewed 4999 times
The wire for the bulldog clip should be a bit fatter, I think, and the black plastic part wraps around the wire ends. Just sayin'!neo0. wrote:Little still life
- Doug Armand
+1StompinTom wrote:The wire for the bulldog clip should be a bit fatter, I think, and the black plastic part wraps around the wire ends. Just sayin'!neo0. wrote:Little still life
but one of your better renders Neo - not sure if thats a compliment or not
Doug
Doug Armand
Doug Armand
just testing lights
Nice chair design. Elegant legs (of the chair)
Its famous Fritz Hansen`s PK9 chair
Thanks, good to know!dcm wrote:Its famous Fritz Hansen`s PK9 chair
- PowStudios
Hi just another testrender. Added another two rooms, still noisy at 2357 s/p.
Pow
Pow
- Rooms still noisy, default render setting 2357 s/p
- newrooms_2157spp_forIndigoWebsiteReduced.jpg (235.3 KiB) Viewed 4782 times
- PowStudios
yummy. 'meniscus' ?Godzilla wrote:OJ Test..
you seem to have very high samples/pixel on every of your 'test' renders. how much is this?
new Orange Juice material ?
ps. very nice SSS
PowStudios wrote: you seem to have very high samples/pixel on every of your 'test' renders. how much is this?
Well, I like my test renders look somewhat presentable
This image was rendered at double this resolution (1050x2400) for 40 hours, 20k samples per pixel.
Users browsing this forum: No registered users and 82 guests
