Blendigo 2.3.x test releases
Locked
aleksandera
Re: Blendigo 2.3.x test releases
Post by aleksandera » Wed Feb 24, 2010 3:00 am
There is no motion blur, no matter how hard I try. :(
aleksandera
Post by aleksandera » Wed Feb 24, 2010 6:39 am
Do you see? :evil:
Post by suvakas » Thu Feb 25, 2010 6:39 pm
Very cool scene !!
Polinalkrimizei
Post by Polinalkrimizei » Fri Feb 26, 2010 1:01 am
Yep that scene is awesome! :shock:
Dougal, nice work, thanks especially for the particle export! Just one request here: could you add support for static particles as well (hair), that would speed up the workflow of creating grass or other randomized instances a lot, cause you wouldn't need to consider the life span of the particles and baking. You see changes in realtime, which gives better control... and children would be nice, too!
aleksandera
Post by aleksandera » Fri Feb 26, 2010 1:15 am
Thank you for compliments, but than doesn't solve my problem
with motion blur :(
dougal2
Post by dougal2 » Fri Feb 26, 2010 1:20 am
aleksandera wrote:Thank you for compliments, but than doesn't solve my problem
with motion blur :(
We need a few more details to know if your scene is set up correctly:
Do you have the relevant buttons pressed in Blendigo to enable motion blur?
What is your animation frame rate? Camera shutter speed? Exposure Time?
It is possible that if the exposure time is too short, or the shutter speed too fast, or the frame rate too high that you won't see any motion blur effect.
aleksandera
Post by aleksandera » Fri Feb 26, 2010 2:02 am
I hawe increased the exposure time.
It's ok now :mrgreen: :mrgreen: :mrgreen:
Thank you!
Post by StompinTom » Sat Feb 27, 2010 11:26 am
- Disabling Subdivision under the mesh options doesn't actually get rid of the subdivision. Tried deleting the temporary scene files but the problem persists. Is there any way to access all the information that the script puts in the .blend file to edit it? Like, is there a way to actually see all the tags that Blendigo saves with the scene file?
EDIT: Scratch that last one, Cap'n. The object was being smooth shaded which was fucking up reflections. All good. Still, is it possible to see all the tags that the script adds to the .blend file?
dougal2
Post by dougal2 » Sat Feb 27, 2010 1:16 pm
If you choose 'ID Property Browser' from the help menu you can explore all the custom indigo properties ob objects, materials, scene etc.
And on that note, I'm offlline for a week; snowboarding in Austria :) hopefully when I get back I'll have some time to address some issues in this thread.
Post by StompinTom » Sat Feb 27, 2010 2:34 pm
dougal2 wrote:If you choose 'ID Property Browser' from the help menu you can explore all the custom indigo properties ob objects, materials, scene etc.
SLIGHTLY jealous :D Have a great time! Thanks a ton for your work!
ozzie
Post by ozzie » Tue Mar 02, 2010 10:31 pm
StompinTom could you past .blend with some example of grass you've rendered in indigo?
Post by StompinTom » Wed Mar 03, 2010 12:40 am
ozzie wrote:StompinTom could you past .blend with some example of grass you've rendered in indigo?
Sure! Give me a little bit of time, very busy today, but I'll try to upload something in the next little bit.
ozzie
Post by ozzie » Wed Mar 03, 2010 8:51 am
Thank you, I'm waiting :).
Post by Borgleader » Sun Mar 14, 2010 6:14 am
Godzilla wrote:Ok, I installed the new script for access to particle support, and whenever I open Blender I get the same error message that Doug was getting..
Error%Broken installation of Blendigo, please reinstall
Abort
I've tried uninstalling and reinstalling, no luck.
When I go into scripts>render>render with Indigo, the same error..
when I make a new scene... same error.
This is the console:
Was this error ever fixed? Because I just bumped into it... Running Windows 7 x64
Locked
