3D wood shader
Re: 3D wood shader
more wood. still the same shader.
- quickrender.jpg (501.77 KiB) Viewed 3060 times
- fenerolina
Re: 3D wood shader
Wow Fused! This oak looks pretty good!
What distracts my eyes now is the simetrical/straightness draw of the wood vains. Would it be possible to add some little knots on the wood? I may ask too much but i really don't know if there're any limits in isl
. Here is the female joint showing a nice wood vain draw.
Thank you!
Thank you!
- 71.JPG (207.1 KiB) Viewed 3042 times
- zeitmeister
Re: 3D wood shader
Very promising, fused!
Can you peek anything from the C4D-wood shader? Because it's quite nice...
Re: 3D wood shader
@Fused:
Hey, that looks quite good!
Perhaps you can even adapt it straight from C4Ds Banzi-Shader for your Cindigo exporter. ;o)
@fenerolina:
At least the one of the effects (curled spot) that you emphasized in your image, you would get easily if you simply put the shader in a small angle "into" the object. You now what I mean?
But yeah, knotholes would be nice too.
@fenerolina:
Re: 3D wood shader
Some low frequency and low density Billow noise into the vein noise should create those locks...
- billowLocks.png (12.4 KiB) Viewed 3020 times
Re: 3D wood shader
What is billow noise?
Etienne
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Re: 3D wood shader
Of one single octave with randomized width, yes. Maya calls it billow at least
Ah, what is Billow noise, sry misread you.
This billow noise is a variation. I don't know how relevant the formula is, and probably many other noise types can do the woodlocks job.Anders Egleus figured the math behind maya's 3D Texture called Volume Noise.
The math that Anders figured out is this
origin = -1 * position * frequency / (scale * 16)
Users browsing this forum: No registered users and 78 guests
