Problem with Microsoft Active X on Indigo site front page
Re: Problem with Microsoft Active X on Indigo site front page
Hi! It works now. Thank you !
So, I'll stay with IE7 until bigger troubles !o)
Now sub-menus are not working properly anymore on IE8.
They are geting cut off from the bottom and forum links appear on top of the menus. I think it's related to that slide show thingy.
That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
Godzilla wrote: you may want to get some images in there that aren't all archviz.. and perhaps images which aren't noisy.
Any plans for doing this?...
Well..menu is still not working with my IE8. I can only select the 1st sub-item from any category and half of the menu gets cut off from the bottom.Soup wrote:That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
- Doug Armand
Sorry I can't help but it works ok here on IE8 Win7x64suvakas wrote:Well..menu is still not working with my IE8. I can only select the 1st sub-item from any category and half of the menu gets cut off from the bottom.Soup wrote:That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
Doug
Doug Armand
Doug Armand
Yeah that's weird, I can't reproduce it either. Is it only on the front page that is doing it? It's probably the flash sitting over top of the menus, try on other pages.suvakas wrote:Well..menu is still not working with my IE8. I can only select the 1st sub-item from any category and half of the menu gets cut off from the bottom.Soup wrote:That's been fixed (hopefully, I just checked in IE8), IE should refresh itself soon for you.
Thanks for the answer guys.
I sloved it. I had "Compatibility view" on for Indigo page.
Where's this setting please suvakas ? I have the same issue as you described, I must try it.
In IE8 it is under drop down list Page > Compatibility View
There's no such option in IE7, too bad. I'll fix that by acquiring a 64 bits system asap.
