Blendigo 2.3.x test releases
Locked
dougal2
Re: Blendigo 2.3.x test releases
Post by dougal2 » Thu Feb 04, 2010 12:13 pm
FakeShamus wrote:I've been wondering if it might be easier to download the mac Blendigo as a simple drag and drop package that you put in a 'scripts' folder somewhere, instead of as an installer, then you just give people directions to set their scripts directory path in Blender. also, didn't there used to be a dialog at Blendigo start-up that asked where indigo was located, and had you browse to it? that seems like a good way to avoid the missing indigo installation problem.
It is possible, however the installer is supposed to do precisely those tedious tasks for you!
Its also possible that I provide Blendigo as its raw source files and then tell you to move this and that there, tweak this edit that and.... well, you get the idea - it's not everyone's idea of fun ;)
Seriously though, there is a standard blender scripts folder (~/.blender/scripts) and it is in fact fairly easy to drop Blendigo in there and have it working without even having to change the scripts directory setting in Blender. The problem on OSX is that this folder is hidden in Finder and not at all easy to get at for the average user.
The installer should be putting the files there (and it looks like it is), however writing the configuration file to specify the Indigo location seems to be massively unreliable.
Perhaps the best solution to this is to re-introduce the "set indigo path" prompt in Blendigo rather than trying to do it automatically. (However, then we also need some way to change that path when you upgrade or move the Indigo app).
The effect I want to aim for is "slick and reliable", so further discussions on this topic for what would suit you, dear end-users, would be appreciated :)
Post by StompinTom » Thu Feb 04, 2010 2:39 pm
- Even when exporting without Sun/Sky enabled, Sun and Sky lightgroups appear. The IGS file has Sun and Sky lightgroup definitions everywhere, between materials, then again after materials, etc.
- Bump settings are still in meters, I believe, though it says mm. Would be great to change that but let me double check that... running on battery right now and writing a paper.
- When a light or camera is selected and you try to export the scene, it tries to get an active UV Layer from the selection, which, being impossible due to the object type, causes it to crash. Selecting a mesh object or nothing then exporting works fine.
- As mentioned before, post-processed aperature diffraction and real ap.diff. should be differentiated and a toggle put in to control both. Problems with circular aperature shape here as well.
- When switching materials in the script window, the albedo channel always goes back to displaying the Color, not Texture. This doesn't seem to impact the actual exporting; it seems to render with the texture, but it's distracting and makes me nervous. Maybe a refresh problem...
- Would it be possible to deactivate bump and exponent maps if they're minimized? Right now the only way to temporarily deactivate textures is to delete their paths in the dialog.
- Still sometimes get 'material index is out of bounds' on perfectly good meshes. Everything works when I construct new meshes, but on existing meshes that are either imported or derived from imported objects (CAD drawings, mostly) it sometimes gives me problems. It could be Vray material and mesh definitions but I don't know if there is a conflict. I've tried deleting all material references and indexes and re-assigning materials and material groups to no avail.
- When I hit render all I get is a grainy image that only gets clearer at an excruciatingly slow pace... Oh whoops, not an exporter issue.
Post by StompinTom » Thu Feb 04, 2010 2:41 pm
Feature request: Possibly an all-in-one material blending option? Making three Blender materials for one blend material stops being fun after a while. No biggie, though, I'm a man and can handle my materials just fine.
Jambert
Post by Jambert » Thu Feb 04, 2010 7:28 pm
dougal2 wrote: Would it be possible to deactivate bump and exponent maps if they're minimized? Right now the only way to temporarily deactivate textures is to delete their paths in the dialog.
+1, really bad for workflow
SaphireS
Post by SaphireS » Fri Feb 05, 2010 3:24 am
+1
Your ad here!
dag
Post by dag » Fri Feb 05, 2010 12:16 pm
If you hit the mesh or material tab 2 times, it switches back to the window you previously were in, but the buttons stay pressed.
Should E really be the default white balance?
Post by StompinTom » Fri Feb 05, 2010 1:33 pm
dag wrote: Should E really be the default white balance?
White (R=100%, G=100%, B=100%) lights stay white with this setting, I believe. I think it responds to all wavelengths pretty evenly.
Godzilla
Post by Godzilla » Thu Feb 11, 2010 4:49 am
Ok, I installed the new script for access to particle support, and whenever I open Blender I get the same error message that Doug was getting..
Error%Broken installation of Blendigo, please reinstall
Abort
I've tried uninstalling and reinstalling, no luck.
When I go into scripts>render>render with Indigo, the same error..
when I make a new scene... same error.
This is the console:
dougal2
Post by dougal2 » Thu Feb 11, 2010 5:39 am
dammit, bitten by Vista's UAC again. I'll see if I can change the installer to write files to your home folder instead.
Post by StompinTom » Thu Feb 11, 2010 7:12 am
Light layers are all wonky. Blendigo defines them after every single material, instead of just once at the end of the IGS file.
Also, when using Background Color to illuminate the scene, its own light layer isn't defined so it takes whatever light layer is first, in which case you can't control it separately from that light group. Had to edit the IGS file to add another light layer to put the other lights on. That also sometimes messes with the colors, though I can't prove that right now.
Otherwise, seems OK...
Post by suvakas » Thu Feb 11, 2010 7:18 am
It's currently not possible to define a light layer for environment. It's always exported to 1st layer.
dougal2
Post by dougal2 » Thu Feb 11, 2010 8:08 am
In that case, I shall name the first layer 'environment' :)
aleksandera
Post by aleksandera » Fri Feb 19, 2010 10:58 am
Does anyone have problems with camera and motion blur, ore is this yust me?
Jambert
Post by Jambert » Fri Feb 19, 2010 8:10 pm
aleksandera wrote:Does anyone have problems with camera and motion blur, ore is this yust me?
Me too :wink:
dougal2
Post by dougal2 » Sat Feb 20, 2010 1:35 am
Me too :wink:
Please elaborate ... :roll:
Locked
Users browsing this forum: No registered users and 101 guests
