screwdrives....
11 posts • Page 1 of 1
Kosmokrator
screwdrives....
Post by Kosmokrator » Tue Jan 16, 2007 7:36 pm
Time elapsed: 5h, 39m, 6s
Done 1296824000.00000 mutations (2134.68971 mutations per pixel)
mutations_per_sec: 63738.06188 (15.68921 micro-secs / mutation)
still on indigo 0.6
Post by suvakas » Tue Jan 16, 2007 8:13 pm
Looks really good and clean !
Also would be a nice scene to test out new blend and sss materials 8)
Wedge
Post by Wedge » Tue Jan 16, 2007 9:01 pm
Very cool! I like the bubbles inside the handle.
It so turns out I'm a carpenter/construction worker and this reminds me of working on the job... hehe.
I like the green handle! :) And that orange/red (at least that it how it shows up on my cheap LCD) is beautiful too!
8bstudio
Post by 8bstudio » Tue Jan 16, 2007 10:51 pm
Very very good! I like caustics!!!
Maybe for metal part of screws it should be more realistic pump the mirror, I mean more chrome material!
Post by OnoSendai » Wed Jan 17, 2007 12:32 am
Hi Kosmo,
great modelling as usual.
Just a couple of things:
the table has too high specular values, it looks a bit like pastic.
try <specular>0.05 0.05 0.05</specular>
And,
needs more DOF effect !! :)
Camox
Post by Camox » Wed Jan 17, 2007 1:33 am
Nice work, the bubbles in the seized looks cool. Very realistically. :D
greetz
Behrendt
Post by Behrendt » Wed Jan 17, 2007 2:41 am
Nice!
Could you share your bump settings please? Not so familiar with this feature of indigo :oops: Would help me very much!
zsouthboy
Post by zsouthboy » Wed Jan 17, 2007 4:27 am
How did you do the bubbles?
Post by suvakas » Wed Jan 17, 2007 5:20 am
zsouthboy wrote:How did you do the bubbles?
Yes, that would be interesting to know.
Spheres with normals flipped?
Post by CTZn » Wed Jan 17, 2007 6:19 am
Yes, that's that simple with 0.6, with a non absorbant, ior-less material (that is, air).
If I understand how 0.7 works, flipping normals is not required but precedence of the bubbles have to be highest in scene.
PS: I've myself started to set a scene with screws and bolts up a few weeks ago, so don't be surprised if I post such an image some day ;) I second the crits here, and also the screws heads are missing some details/contrast, maybe because of postprod ? Give it one more shot please :)
Kosmokrator
Post by Kosmokrator » Wed Jan 17, 2007 7:58 am
ok lets answer...the bump settings is...like this in xml code...
	<material>
			<name>13 - Duighgf</name>
			<phong>
				<diffuse>0.384314 0.380392 0.356863</diffuse>
				<specular>0.0803922 0.0803922 0.0803922</specular>
				<exponent>244.692</exponent>
				<fresnel_scale>1.0</fresnel_scale>
			<albedo_texture>
				<uv_set>albedo</uv_set>
				<path>Textures/tool.jpg</path>
				<gain>1.0</gain>
				<exponent>2.2</exponent>
			</albedo_texture>
			<bump_map>
				<path>Textures/too bumpl.jpg</path>
				<gain>0.0007</gain>
				<exponent>1.0</exponent>
			</bump_map>
			</phong>
		</material>
for bubbles inside the screwdrive i use simple streched sheres with dielectric material and ior of 1.33 the plastic have ior 1,5!i turn off the bidirectional because the bubbles does not render if bidir was enable..that all..thnx for your good words and suggestions!
