There are some attributes that make more sense then others, but yes... the frame upload comes to mind.OnoSendai wrote:You mean a way to modifiy all settings in the GUI?
Imagine that you've exported a scene, will you export it again just because you wanted to change say, max_depth or large_mutation? You might want to extend/shorten the halt_samples_per_pixel or halt_time due to something that come between. Change from MLT to PT. Change turbidity value, or the camera f-stop. Even if not on the fly it would be welcome that some of these attributes could be changed without having to dwell into the xml file, or having to make the changes and export it again, when for the sake of a few values you have to export all scene.
