Well, I thought to start a new thread for this one.
In fact I found that there where still two important things missing in the previous version. First there was the issue of mixing light sources that wasn't possible without post production of the exported xml materials. Notably the <gain> tag for meshlights. Second, if an infinite ground plane is created the 'Default' material used for that is rgb(1,1,1) arbitrairely.
This version of the export script tries to give a solution for both inconveniencies. Since pictures tell more, certainly here I suppose
All settings default, using Background with color value rgb(0.1, 0.1, 0.1), LFactor 200.0 and material emit 0.9
All settings same as above, only with default sunsky
What can I say more then that I hope you all like it and click the following link to grab it. And, oh, don't forget to read the readme.txt included..
Updated date 19 january 2007
Exporter for Indigo 0.6 v. 63beta4
Greetings from sunny Amsterdam,
Jan
