- 3D Software: SketchUp
by Pibuz » Wed Dec 16, 2009 11:19 pm
OnoSendai wrote:Last render is fantastic!
+1, but the glass base is floating!
SPOTTED! AH!
by zeitmeister » Wed Dec 16, 2009 11:21 pm
That doesn't sound good.
Would you try to re-render your last glasses with minor values in the cauchy-coefficient input field? It should increase reality, but rendertime too.
And I noticed that the lying glass on the left seems to hover... should it kind of fall down? If yes, you could apply a motion-blur tag on it and see what happens.
ritter
by ritter » Wed Dec 16, 2009 11:48 pm
Pibuz wrote:OnoSendai wrote:Last render is fantastic!
SPOTTED! AH!
Moin
....thank you for the hint ,i did not recognize that.....
regards Axel
@zeiti :
werds testen ...
ritter
by ritter » Thu Dec 17, 2009 8:49 pm
Hi
Small update :
regards Axel
- glasn.jpg (398.65 KiB) Viewed 8275 times
Doug Armand
by Doug Armand » Thu Dec 17, 2009 8:51 pm
Gorgeous.
Is the detail on the glass a bump/displacement map?
Doug
Doug Armand
ritter
by ritter » Thu Dec 17, 2009 9:06 pm
Hi Doug
"Is the detail on the glass a bump/displacement map?"
No bump or displacement, these are the original highres meshes from Zbrush....
regards axel
Doug Armand
by Doug Armand » Thu Dec 17, 2009 9:45 pm
wow even more gorgeous then
Doug
Doug Armand
Stromberg
by Stromberg » Fri Dec 18, 2009 6:54 am
How could i have missed this :O
Amazing detail and render
by suvakas » Fri Dec 18, 2009 7:59 am
Indeed !!
Jambert
by Jambert » Fri Dec 18, 2009 11:09 am
nice
by neo0. » Fri Dec 18, 2009 11:15 am
Are you using sun/sky.. You should try it with a studio setup...
dakiru
by dakiru » Fri Dec 18, 2009 11:42 am
neo0. wrote:Are you using sun/sky.. You should try it with a studio setup...
Even with this light setup such a detailed modelling looks great
djegoo
by djegoo » Fri Dec 18, 2009 7:15 pm
OH MY GOD the details are soooo sensual....
ritter
by ritter » Sat Dec 19, 2009 1:44 am
yes, sun&sky were used for lighting...
maybe a studio setup render follows ...
small Whaletest :
- potti.jpg (392.33 KiB) Viewed 8044 times
by CTZn » Sat Dec 19, 2009 4:44 am
A smily
baleen whale ?
Fine glasses indeed... ahw, I was hoping for rendertime displacement
