Bandar
by Bandar » Sat Jan 13, 2007 2:55 pm
I spent the last night with indigo_07
Here is the first result:
by CTZn » Sat Jan 13, 2007 3:12 pm
Cool, are you a TopMod user ?
I have some difficulty to read the shape clearly, like its merging into some transparency... I can see there is sss but my concern is different... you got me ?
Bandar
by Bandar » Sat Jan 13, 2007 3:38 pm
Yep, that's TopMod.
Here is the blend to explore:
http://butz-e-matic.de/pix/topmod_test3.blend
The transparency is due to my ignorance how all the values effect the new materialsystem.
Here is another version, that is less transparent:
And this might be the material that I used for the 2nd picture (don't remember, if i changed it in the meantime):
<medium>
<name>rubber</name>
<ior>1.0</ior>
<rgb>
<rgb>0 2 10</rgb>
</rgb>
<precedence>20</precedence>
<subsurface_scattering>
<rgb>
<rgb>2 12 1</rgb>
</rgb>
<phase_function>
<uniform><value>4</value></uniform>
</phase_function>
</subsurface_scattering>
</medium>
<material>
<name>green</name>
<specular>
<internal_medium_name>rubber</internal_medium_name>
</specular>
</material>
IanC
by IanC » Sat Jan 13, 2007 4:04 pm
That is just beautiful.
Thanks for the code+file, I've found a scene that crashes in wine with those mats, but doesn't with yours.
domparis
by domparis » Sat Jan 13, 2007 6:20 pm
Very nice especially the second one, top notch !!!
and thanks for the code
Dom
manitwo
by manitwo » Sat Jan 13, 2007 9:54 pm
Phil
by Phil » Sat Jan 13, 2007 10:12 pm
Hi Bandar,
this is incredible
, thanks a lot for sharing your model and settings!
Regards, Phil
Camox
by Camox » Sun Jan 14, 2007 3:07 am
awesome, and THX for sharing your settings.
greetz
by fused » Sun Jan 14, 2007 3:47 am
impressive
Bandar
by Bandar » Sun Jan 14, 2007 10:01 pm
And another one
I will post a png with higher res to the gallery...
And here are the material settings:
<medium>
<name>rubber</name>
<ior>1.2</ior>
<rgb>
<rgb>0 0.45 0.5</rgb>
</rgb>
<precedence>10</precedence>
<rgb>
<rgb>0.1 0.5 5</rgb>
</rgb>
<phase_function>
<uniform><value>40</value></uniform>
</phase_function>
</medium>
<material>
<name>green</name>
<specular>
</specular>
</material>
by OnoSendai » Sun Jan 14, 2007 10:15 pm
WOW...
that's just an amazing material!
congrats!
Bandar
by Bandar » Sun Jan 14, 2007 10:26 pm
And congrats + 100000 thanks to you for coding that incredible renderer!
manitwo
by manitwo » Mon Jan 15, 2007 12:57 am
incredible!
Lotuspec
by Lotuspec » Mon Jan 15, 2007 1:31 am
Bandar wrote:
<phase_function>
</phase_function>
What does "value" do in the phase function?
Users browsing this forum: Google [Bot] and 39 guests
