Blendigo 2.2.8
Re: Blendigo 2.2.8
New issue, color can't be change in gradient when "specular reflective" enable
Re: Blendigo 2.2.8
another little issue, when texture path is written, material is allways exported with texture. If I desable texture to choose color, texture path isn't desable, I need to erase texture path.
Re: Blendigo 2.2.8
dougal2 wrote:For this to happen you would have to disable both the sun and sky layersdakiru wrote:and when there is no sun during the "sun a sky" setting it automatically switches to "background color"Jambert wrote:There something strange with sunsky. If I desable sun, it renders with a white background. It's the first time I try it, I thought it just desable sun but still generate gradient sky?
edit: sorry it works, my sun was on another layer...
Ok, thank you for telling.
Re: Blendigo 2.2.8
little issue, blendigo crash some times and quit if mesh menu is open with no mesh selected in blender. Don't know more
Re: Blendigo 2.2.8
Dougal, could you add a shader rendering type, to export all mesh with white diffuse material. I know it's possible with clay but it needs to create a white diffuse mat and apply it to a mesh. A shader type would be nice and better for workflow.
thx
thx
Re: Blendigo 2.2.8
So...when will the fix be available?dougal2 wrote:Camera motion blur is fixed:
Re: Blendigo 2.2.8
in the next couple of days.pvbeeber wrote:So...when will the fix be available?dougal2 wrote:Camera motion blur is fixed:
Re: Blendigo 2.2.8
Fixed in next release.Doug Armand wrote:Clay Render doesn't work with external materials
Re: Blendigo 2.2.8
I don't see how this is any different from the 'Clay' mode ??Jambert wrote:Dougal, could you add a shader rendering type, to export all mesh with white diffuse material. I know it's possible with clay but it needs to create a white diffuse mat and apply it to a mesh. A shader type would be nice and better for workflow.
thx
- Doug Armand
Re: Blendigo 2.2.8
nice on both this and motion blur fixes (if it really is fixeddougal2 wrote:Fixed in next release.Doug Armand wrote:Clay Render doesn't work with external materials
Doug
Doug Armand
Doug Armand
