hi, i have been trying maxigo and i noticed that if i use an environment map there is no way to rotate is around the scene using maxigo UI (am I right?). Please if there is, tell me how to do it. If not, can you please implement it in the ui?
Thank you
[req?] Evironment map rotation
Re: [req?] Evironment map rotation
You can rotate the background material 360 degrees around the Z(up) axis.
Rotating simple environment map is not supported by Indigo. The only reason it is still present in Maxigo UI is because it sometimes produces better lighting (less fireflies) and it's a bit faster to set up than a material.
- maxigo_rotmat.png (19.63 KiB) Viewed 2525 times
Thanks suvakas.
