Хорошо иметь Compositing теги как в Cinema4D.
Допустим для меня это необходимое, чтобы разместить дополнительный источник освещения и сделать его невидимым и невидимы в отражение, например, зеркало, без этого тега это является проблемой.
Это очень трудно настроиться фона неба, это хорошо, что независимо от освещения,
Отец-в-законе, увеличительное освещенность, фон неба не изменится и регулируется отдельной настройке.
Compositing Tag
Compositing Tag
- Screenshot - 14_11_2009 , 11_46_57.png (197.37 KiB) Viewed 4412 times
- Screenshot - 14_11_2009 , 12_09_11.png (31.04 KiB) Viewed 4410 times
- Screenshot - 14_11_2009 , 11_46_16.png (157.34 KiB) Viewed 4409 times
- Screenshot - 14_11_2009 , 11_42_01.png (216.51 KiB) Viewed 4407 times
- Screenshot - 14_11_2009 , 11_41_32.png (49.94 KiB) Viewed 4408 times
- Screenshot - 14_11_2009 , 11_41_17.png (45.47 KiB) Viewed 4406 times
- Screenshot - 14_11_2009 , 11_40_50.png (192.01 KiB) Viewed 4406 times
- zeitmeister
Re: Compositing Tag
I think that this is not possible,
and it doesn't make much sense to me due to Indigo's aim to achieve real world camera behaviour and physical correctness.
- pixie
Re: Compositing Tag
Maxwell achieve it, isn't maxwell physical correct?zeitmeister wrote:I think that this is not possible,
Re: Compositing Tag
It is good to have Compositing теги as in Cinema4D.
Let's admit for me this necessary to place an additional source of illumination and to make its invisible and are invisible in reflexion, for example, the mirror, without it тега it is a problem.
It is very difficult to be tuned a sky background, it is good that irrespective of illumination,
The father-in-law, magnifying light exposure, a sky background will not change and regulated to a separate tuning
Re: Compositing Tag
Its currently not possible in Indigo.
- PureSpider
Re: Compositing Tag
Try n achieve an light thats invis to the bare eye but is emitting light in real life... can you manage it? No? So it's not physical correct obviously.pixie wrote:Maxwell achieve it, isn't maxwell physical correct?zeitmeister wrote:I think that this is not possible,
- pixie
Re: Compositing Tag
But why do you have to actually see the light? I mean, despite being everywhere you don't actually see it unless you use SSS. You can get physical correct light despite hiding the light emitter, as long the light itself is physical correct.PureSpider wrote:Try n achieve an light thats invis to the bare eye but is emitting light in real life... can you manage it? No? So it's not physical correct obviously.pixie wrote:Maxwell achieve it, isn't maxwell physical correct?zeitmeister wrote:I think that this is not possible,
Now you make me think of it...
- zeitmeister
Re: Compositing Tag
Interesting point, pixie!
In real world, you always "see" the light sources because they are situated in kind of materials which reflect it; like light bulbs etc... so you "see" the light source. As you said for example the sun; you only see her because a) of the atmosphere or dust particles in space (SSS or very small reflective surfaces) and b) because of her light emitting surface.
Pure light by itself is indeed invisible.
But I think that Indigo works with emitting surfaces, so they already "reflect" their own emitted light.
Hm.
Hm.
