Glass test
Post by OnoSendai » Sun Nov 12, 2006 6:20 am
Becco:
It should all be correct, i just have to be careful :)
First decent result:
Thanks for the model Kosmo!
Post by OnoSendai » Mon Nov 13, 2006 12:07 am
Another test, with fixed reflection code:
tungee
Post by tungee » Mon Nov 13, 2006 12:21 am
this looks cool!
filippo
my glass
Post by filippo » Mon Nov 13, 2006 1:27 am
my glass.....first test...hi thanks
Post by OnoSendai » Mon Nov 13, 2006 1:32 am
Another one, short render time
edit: replaced with better image
Post by OnoSendai » Mon Nov 13, 2006 10:37 pm
I've made a post about this on my blog, has some purty pictures :)
http://www.indigorenderer.com/blog/?p=30
manitwo
Post by manitwo » Sat Jan 13, 2007 2:48 am
OnoSendai wrote:For the record:
there is no way to model/render liquids in a glass entirely correctly in any released version of Indigo.
Depending on how this new technique works out, the next version should have support for this.
Now the first 0.7 test version is out and i'm wondering if it's possible now?
Do we need special settings for the materials like precendence or something?
We have to enable also polarisation in the infile.txt i guess?
Post by OnoSendai » Sat Jan 13, 2007 2:53 am
Yes, correct rendering of glass/liquids is possible now.
Make the model to the specifications in the first post.
You'll need to define two 'medium' elements in the xml, glass and water.
Give glass a precedence > than that of water, say 20.
Set water precedence to 10.
(air always has precedence of 1).
Then create two specular materials.
The <internal_medium_name>'s should be set to glass and water respectively.
Polarisation doesn't have to be enabled.
manitwo
Post by manitwo » Sat Jan 13, 2007 2:57 am
thank you for your light-fast answer
Post by fused » Sat Jan 13, 2007 3:03 am
crap....
I knew there had to be something wrong with this:
forgot the precedence thing... :(
manitwo
Post by manitwo » Sat Jan 13, 2007 3:26 am
sorry but i have another question: 8) :)
Can i give a sss-mat also a precendence tag? if yes - how?
Want to try that: http://www.indigorenderer.com/joomla/fo ... php?t=1053
Post by CTZn » Sat Jan 13, 2007 3:28 am
That's great Ono !
Any hint what precedence is about, in short ? What's the relation with ior ? Er, why 10 or 20 not 0.2 or 200k ? In short, heh !? Got some web ressource about that ?
Thx
Post by OnoSendai » Sat Jan 13, 2007 3:28 am
Yes..
	<medium>
		<name>scattering_medium</name>
              <precedence>10</precedence>
		<ior>1.5</ior>
			<rgb>
				<rgb>10000.0 5 5</rgb>
			</rgb>
		<subsurface_scattering>
				<uniform>
					<value>10</value>
				</uniform>
			<phase_function>
				<uniform/>
			</phase_function>
		</subsurface_scattering>
	</medium>
should work
manitwo
Post by manitwo » Sat Jan 13, 2007 3:31 am
thanks again 8)
deltaepsylon
Post by deltaepsylon » Sat Jan 13, 2007 9:05 am
awsome..... :D
Users browsing this forum: No registered users and 138 guests
