Indigo closes while rendering
I have a problem. Indigo closes everytime I am trying to make a render. Sometimes one hour after initiation and sometimes more (four, five hours).
It does not show any messagge, just closes down and does it. I thought that was related to an error of the file but after some modifications that I have made, it has the same behavior. I tried to do it in other computer and did not work either. Help!
With other file is the same....Indigo Closes !!!
My computer is:
AMD ATHLON XP 2200+
1.34 GHZ Y 1GB DE RAM.
Thank you,
Daniel
My computer is:
AMD ATHLON XP 2200+
Thank you,
Daniel
Look here, if that was the file Indigo would not start render.
http://www.indigorenderer.com/joomla/fo ... php?t=1035
Oh yes I misread you sorryIndigo closes everytime I am trying to make a render.
Ever get the task manager opened while you are rendering, thought once the preprocess is done memory consumption is very stable AFAIK, should be something else, again... what arneoog said ? there is a log.txt in Indigo's folder, what says ?
Is that all ?
Weird, if that's not a memory issue I have no clue of what is happening... Please answer these questions:
1° What are the size of the file (optionally, how many triangles are there ?)
2° can you check in the Task Manager if ram hits a peak ?
3° t'es french Daniel ? (1GB DE RAM)
4° version of Indigo used ?
qinjuehang
