Indigo 2.2.5, with Mat Editor beta 4
Re: Indigo 2.2.5, with Mat Editor beta 4
Post by Whaat » Tue Nov 03, 2009 10:13 am
Some material database bugs/requests: (sorry if these are duplicates)
- Make the preview scenes useful for emitting materials. In SkIndigo, I set the preview model's emission scale to balance the other emitting elements in the preview scene. That way, when an emitting material is created, it is exposed properly. Can you do something similar? Another option is a separate preview scene for emitting materials
- Option to set the subdivision of the preview model or make it more useful for displacement materials
- A better preview scene for SSS materials
- A preview scene for 'thin' materials like fabric, or diffuse transmitter materials
Doug Armand
Post by Doug Armand » Tue Nov 03, 2009 4:07 pm
Whaat wrote:Some material database bugs/requests: (sorry if these are duplicates)
+1 to all of those - especially the subdivision for displacement
Post by Pibuz » Wed Nov 04, 2009 11:50 pm
I post here some tests I did on exit portals.
I spotted something going wrong for some render methods, hope you can fix those.
portals test small.jpg (839.93 KiB) Viewed 12146 times
Post by suvakas » Thu Nov 05, 2009 12:12 am
@Pibuz
What's wrong exactly ?
That bidir off renders more slowly? I think that's normal.
Post by pixie » Thu Nov 05, 2009 12:15 am
suvakas wrote:@Pibuz
From my experience bidir is actually faster in giving a cleaner result, although it can dark glass a lot.
Post by PureSpider » Thu Nov 05, 2009 12:15 am
Single PT shows sun spots as a few fireflies only...
Post by Pibuz » Thu Nov 05, 2009 12:24 am
Exactly.
- Single PT shows no direct illumination at all;
- Single MLT shows strange artifacts, which are completely unexpected;
- Single Hybrid is a worse version of Single MLT: artifatcs will converge in a much longer time;
- Alpha Rendering is not working with Exit portals ON (completely white image).
Post by suvakas » Thu Nov 05, 2009 12:43 am
Really? Ok. Good to know. =)
I thought it is slower for indirect lighting.
@Pibuz
Exit portal is a geometry. That's probably why it is altering the alpha. But it's good idea indeed. Alpha should ignore the portal mesh. Ono?
amadex
Post by amadex » Thu Nov 05, 2009 5:12 am
Hi all! When it will be available a Mac OS X version of this 2.2.5? Or, even more important, do you plan to release the betas simultaneously for Win and Mac? BR
rendigo
Post by rendigo » Thu Nov 05, 2009 7:30 pm
amadex wrote:Hi all! When it will be available a Mac OS X version of this 2.2.5? Or, even more important, do you plan to release the betas simultaneously for Win and Mac? BR
I don't know if you are aware of the beta download page at http://www.indigorenderer.com/download/beta/ - the latest Mac version to be found there is 2.2.1.
Post by neo0. » Fri Nov 06, 2009 11:48 am
A new idea I though of for blend materials. You create your two constituent materials and then you create a blend material. After that, you could just drag the two materials icons onto the icon for the blend material, at which point, they would slide into place as miniature icons overalayed over the larger blend material icon.. This is of course assuming that that materials are represented as icons..
EDIT : Why are the smiley's and signatures gone?
Post by pixie » Fri Nov 06, 2009 12:05 pm
neo0. wrote:EDIT : Why are the smiley's and signatures gone?
Because you're in Indigo News & Announcements's section.
Post by neo0. » Fri Nov 06, 2009 12:45 pm
Wow, I really feel dumb now. :(
Post by CTZn » Sat Nov 07, 2009 2:31 am
Don't, you where fooled. Ono can use smileys in this forum ^^
Post by fused » Sat Nov 07, 2009 2:36 am
me too 8)
Users browsing this forum: No registered users and 119 guests
