lego car - first render
6 posts • Page 1 of 1
losbellos
Post by losbellos » Fri Oct 30, 2009 8:21 am
Hi, well I have been a sort of user of indigo in the past, but today I tried out the new version, and I must say its amazing. Here is a lego car render.
Stromberg
Re: lego car - first render
Post by Stromberg » Fri Oct 30, 2009 9:01 am
Realy cool render :)
Maybe get some emitters in there aswell, as it does look abit dull right now.
losbellos
Post by losbellos » Sat Oct 31, 2009 2:58 am
little update with emitters.
Post by CTZn » Sat Oct 31, 2009 4:16 am
Thanks for sharing your pleasure, nice ones losbellos !
Stromberg
Post by Stromberg » Sat Oct 31, 2009 1:59 pm
Looks better :)
Just wondering what modeling app are you using?
Since i can see alot of hard edges and poly's..
losbellos
Post by losbellos » Sat Oct 31, 2009 8:02 pm
Stromberg wrote:Looks better :)
Well, this case I use Mlcad, wich is designed especially for lego, there are parts which you can put together, and then used an lwo converter, which is messed it up quite much, so I had to block by block, and find, and reverse the wrong normals. Well, maybe an edge rounding option would be good for indigo as well. Otherwise it might be possible to chamfer all of them, with more or less headeache, maybe even some sss would help. But for now, its ok. I will use this model as a part of material exercise in my book, light and shadow with cinema 4d. this was basically just a test. I wanted to include one of "those" unbiased renderers. It could be the indigo will be the one... I am sort of staisfied with the speed of rendering.
Users browsing this forum: No registered users and 185 guests
